Manny -mannytranny said:As a note....I did the 5th gear swap and ended up changing out the trans fluid. My car has spent it's whole life in the South, in Austin Tx and now in Southern Ca. 85k miles. The fluid looked kinda crappy....glad I changed it.
Asked the dealer specifically for G070xxx and they showed me that G055 has superseded the G070. $14 qt, hope it is synthetic.
Shifting seems a wee bit smoother, but nothing big.
l_c said:windsolar, I wonder whether the gearbox oil level has been checked on your vehicle. I know it's not noticeably consumed during use; but, opening the plug is a chance to take a little sample of the fluid, to see its color/consistency.
If you get a little sample of it and it looks really good, and it's shifting nicely, then perhaps you ought to wait another couple of years for the fluid change.
I don't recall what the Bentley maintenance chart says, as far as the "change" interval (it might be 100k miles). I don't have time to look for that information right now. Larry
jetta said:here is some info about manual transmission fluid that I post it.
http://forums.tdiclub.com/showthread.php?t=249134
well, the bottles are the samejerry_m said:No, Castrol doesn't make G52! 100% sure.
Could anyone do a VOA for those oils:
G 052 171 A2;
Fuchs TITAN SINTOFLUID SAE 75W-80 (GL-5).
I believe these both should be the same and Fuchs is expected to be tranny oil supplier to VW.
So is it the G060 or G070 that you recommend? Have you tried just pure MTL without MT90 mixed in?scurvy said:I recently switched out the MTL/MT90 mix in the NB with G060 fluid and was immediately impressed at the excellent shift quality and how it made the car feel peppier overall.
So much so that I dumped the MTL in my transmission in favor of G070 at the recent West Allis WI GTG - even though it only had about 30k km on it. I had a very slight feeling of slow synchronizer engagement and a few notchy shifts with MTL (still better than the stock fluid, though). All of that is completely gone with G070 and the shifts are nice, light & precise now.
I used to recommend MTL but the OEM fluids have gotten so much better so quickly I now recommend G070 over everything else.
Either one is an upgrade AFAIC - G070 seems to be the most widely available one these days.Diesel Addict said:So is it the G060 or G070 that you recommend? Have you tried just pure MTL without MT90 mixed in?
Did you also realign the shifter linkage and lube its sliders at the top of the transmission? Takes all of 5 minutes and can make a world of difference in shift quality.dieselpower04 said:What about notchy shifts with G060 compared to G052? My '04 Golf is having some hard shifting issues...I don't like it one bit. I had the gear oil changed in April (OEM to G060, @ 98k).
scurvy said:Did you also realign the shifter linkage and lube its sliders at the top of the transmission? Takes all of 5 minutes and can make a world of difference in shift quality.
http://forums.tdiclub.com/showpost.php?p=1937168&postcount=7dieselpower04 said:No I didn't but I can look up how to! Or you could tell me!!
THANKS SCURVY!! Will try tomorrow!!!!!scurvy said:
Since this thread spans almost 4 years, F/F (fast forward) to December 12, 2009 for the latest updates (@ the local VW dealer).SUNRG said:If your transmission specifies G52 fluid I highly recommend sticking with it as opposed to changing it out for one of the popular/common replacement manual transmission fluids because the viscosity of G52 is much thinner:Viscosity Comparison @ 100 C
With just over 43,000 miles on my 2004 Golf TDI 5-speed I drained my manual transmission fluid, re-filled with Motul Gear 300, and I brought samples of both the used G52 and new Motul Gear 300 to my local CAT fluid analysis lab.10.6 = Redline MTL 70-80
13.8 = Amsoil MTG 75-90
15.2 = Motul Gear 300 75-90
15.6 = Redline MT-90 75-90
15.0 = Elf Tranself Synthese FE 75-90
16.7 = Motul MOTYLGEAR 75-90
6.3 = OEM G52 (part numbers G052726A2 / G05272601)
Since I had written on the G52 oil sample label 75w-90 the lab viscosity tested the sample twice - both times returning a V@100c of 6.4.
My thinking was that either the OEM oil sheared way down OR the OEM fluid started out much lighter than the expected 75w-90.
So, I went to my local dealer this morning, bought a liter of G52, then drove to my local CAT fluid analysis lab and watched as he tested its viscosity right in front of me.
The result: VOA viscosity of G52 = 6.3
OEM G52 did not shear down at all in 43,000 miles of use:V@100c: New G52=6.3, G52 after 43,000 miles = 6.4Additionally, in these crazy unseasonably warm temps the Motul Gear 300 shifts fine - but early yesterday morning when temps were in the mid 40s - the first few shifts with Motul Gear 300 were noticably more effortful than the G52 ever was - even at below 0 temps.
Point being that even though Motul Gear 300 has an outstandingly low pour point (flows to -60) - **the 75-90 viscosity of common gear / manual transmission oils is IMO not suitable for use in VW transmissions where G52 is specified.**
OEM G52: 43k UOA
Motul Gear 300: VOA (this is as expected from a 75w-90 oil)
