Old December 15th, 2018, 20:39   #1
montanajetta
Default Mass Air or Turbo issue?
New to TDI's and the forum. I have been searching the forums for an answer, with no luck. I have a 2002 Jetta Wagon have had a reduction in mpg and no power above 3400 rpm. I logged my Mass Air on my VCDS (as stated on ross tech) and noticed the graph was surging. I assumed I needed to replace my mass air sensor, until I noticed my boost followed the same wave. Does this still lead to a bad mass air sensor or another problem? Thanks for the help!
https://www.dropbox.com/s/gu9u4g2spp...graph.jpg?dl=0
https://www.dropbox.com/s/snafusgd50...graph.jpg?dl=0
montanajetta is offline   Reply With Quote
Old December 15th, 2018, 21:01   #2
2000alhVW
TDI(s): 2000 Golf
Seems VERY similar to my situation before I got it mostly fixed. My car had the exact same "MAF waves". Step on the pedal, MAF briefly gives a proper value, then falls, then comes back up a bit, falls, comes back up, falls. Each time the bounce gets lower and lower.
My car ran so poorly with the MAF plugged in, I drove with it unplugged just to be able to achieve high way speeds. The car was just plain gutless, and would slow to a stop up hills.
I would recommend a few easy, free tests:
First, unplug the MAF and see what changes.
Then unplug the vacuum line that goes down to the turbo vane actuator.
When I unplugged the vacuum line, it was like this weird...'calming of the storm'. Where my car had low power, but it...worked. I step on the pedal, it went faster. All my MAF graphs immediately whipped into shape, and it worked perfectly, just without the boost.
I eventually narrowed my issue down to my turbo vane actuator rod being out of adjustment and over boosting immediately, so my car would actually trip into limp mode at the very first throttle demand. It would literally go into limp mode on flat ground within .5 seconds of being started up.
When the computer trips limp mode, it cuts fuel heavily (among other things). So you've got low power on top of low power conditions.
When I disconnected the vacuum line (effectively removing the turbo from the equation), the turbo could no longer overboost and trip limp mode, so the computer spit proper fuel into the car based on proper MAF values.
But it could be other things too
2000alhVW is offline   Reply With Quote
Old December 15th, 2018, 21:14   #3
montanajetta
Interesting, I will try unplugging the mass air sensor tomorrow. Will the car go into limp mode without throwing a code? I donít seem to have any codes, and can still get up to speed and hold speed up hills, but after 33-3400 rpm itís like the can loses almost all power....
Old December 15th, 2018, 21:27   #4
2000alhVW
TDI(s): 2000 Golf
Originally Posted by montanajetta View Post
Interesting, I will try unplugging the mass air sensor tomorrow. Will the car go into limp mode without throwing a code? I don’t seem to have any codes, and can still get up to speed and hold speed up hills, but after 33-3400 rpm it’s like the can loses almost all power....
"Can car go into limp mode without throwing a code?"
Short answer: Yes. My car NEVER threw a CEL (dash light illuminated) for ANYTHING, despite having pending and current codes logged. Additionally, I could drive my car for hundreds of miles in "limp mode" before ANY codes would show up when checking via VCDS. This sent me into somewhat of a fury that these ECMs are quite stupid.
Long answer:
I'm not really sure the answer of this. For a couple of reasons...
I've found this particular question/topic/point to be seldom directly talked about. The relationship between limp mode and CEL has gotten mixed answers when I've read.
The ambiguous part, for me, is the "limp mode" itself. Like, what is it really? I've poked around quite a bit with VCDS and haven't found any sort of data box or anything to indicate whether limp mode has been tripped or not. Maybe this is the fact that my car is an early version (2000) and not as intelligent as later models, but I'm almost convinced that the computer itself might not even know it's operating in limp mode.
It might just dumbly be bumped over to an alternate fuel map, similar to, say, open loop fueling during cold starts on a gas car.
To me, it would be super obvious computer logic. IF overboost, then throw into limp mode immediately (which it does) and then trip an overboost code which lights up CEL.
But no such thing happened for me. In my case, the ECM was utterly useless, and VCDS scanning/datalogging was only mildly helpful. I only solved my issues by getting down into nitty gritty old-fashioned mechanical diagnosis/logic.
Old December 15th, 2018, 21:50   #5
indysoto
indysoto's Avatar
Clogged fuel filter? Or gunked up manifold?
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
Old December 16th, 2018, 04:53   #6
montanajetta
Long answer:
Very interesting. I have been having this issue for a while. Good to see some possible answers.
Old December 16th, 2018, 04:58   #7
montanajetta
I just replaced the fuel filter and ran a can of diesel purge. I also pulled the inter cooler and drained the oil at the same time.
I was leaning towards either the mass air sensor or a possible clogged intake manifold. I saw the tutorial on cleaning, is there a way to tell if it is clogged without pulling it all the way off?
Old December 16th, 2018, 07:26   #8
eddieleephd
Fuel Economy: 38mix / 47@70-75
Look down the egr and see inside.
http://forums.tdiclub.com/showthread.php?t=179589
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old December 16th, 2018, 08:24   #9
montanajetta
I will check the EGR when I get home. Thanks for the link!
Old December 16th, 2018, 17:10   #10
montanajetta
So I unplugged the Mass Air Sensor, No noticeable change. Not sure what that means. Any ideas? Pulled off the EGR and then the intake. It might be some of the problem.
https://www.dropbox.com/s/lfu771wcg1...%2008.jpg?dl=0
https://www.dropbox.com/s/bo9vudxbjs...%2039.jpg?dl=0
https://www.dropbox.com/s/924kel9gq3...%2047.jpg?dl=0
Old December 16th, 2018, 20:00   #11
indysoto
indysoto's Avatar
Looks clogged!
It is the SUM = Your Problem
Merry Christmas!
You got a lump of Diesel coal
Old December 16th, 2018, 21:16   #12
mrfiat
Fuel Economy: 38.5 mpg (in town - trying to improve it)
I paid the NAPA machine shop $30 to clean my intake out. It's a messy job. People also burn out the gunk with a torch. (read up on the method here before trying it)
mrfiat is offline   Reply With Quote
Old December 16th, 2018, 23:07   #13
Nero Morg
Nero Morg's Avatar
NAPA does that? So you mean the four days of soaking in Zep and scrubbing could have been avoided? I still have a flathead screwdriver covered in that sludge.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old December 17th, 2018, 00:41   #14
ToxicDoc
TDI(s): 2001 Jetta
Any general automotive machine shop can do it - some NAPA, Car Quest, locations have them. They just run parts like that through the hot tank (or whatever is currently in since many have gotten away from the chemicals and EPA requirements).
ToxicDoc is offline   Reply With Quote
Old December 17th, 2018, 04:26   #15
montanajetta
Awesome. Going to try and clean it today. I’m not sure anyone in town will touch it, so I have been reading up on the cleaning methods. What about the passages is the block? Should I clean those at this time?
Difference between Air Mass Specified, and Air Mass Actual WEGSVDUB OBD Scanners 8 August 23rd, 2013 09:14
Mass Air Flow sensor issue kpenner TDI 101 13 December 1st, 2010 09:34
Mass air flow issue Rod 525 TDI 101 5 August 15th, 2008 18:38
air mass leoncupra OBD Scanners 4 May 9th, 2007 16:44
137,000 miles, 4000 miles ago had a new turbo, fuel filter, and mass air sensor... brian rhodes VW MKIV-A4 TDIs (VE and PD) 11 May 13th, 2002 11:16
Page generated in 0.22914 seconds with 13 queries
[Output: 131.67 Kb. compressed to 110.91 Kb. by saving 20.76 Kb. (15.77%)]
