compu_85
Gadget Guy
The license plate lights are standard bulbs. I don't recall what lamps the turn signals take, I think it was the same as the front turn signals.
-J
-J
Raidio Shack part numbers, por favor? Pics after dark, or it didn't happen!Update, just went to radio shack and got some 50 ohm, 10 watt resistors. They drop the power to 8.3 volts, making the brightness just about perfect Cost for two was under $2.50.
-J
Can you pull a forward voltage on that LED with a meter? Sounds like it's running about 3.6 to 3.7 volts at 1000 mah, pretty common for an LED that puts out that kind of light, probably an R2 or R5 Cree LED rated at 320- 350 lumens output.Yes, the center lights are too bright. I'm going to add some resistors in tomorrow to dim them down a bit, I had ones on had that totaled about 590k and it seems to make the brightness just about perfect.
FWIW the inner fixtures (less the middle segment) draw 3.6 watts at full brightness.
-J
Any idea what the Chinese coding number is for the BCM? That would help a lot!Hello all those are cool set are they not... Well im the guy that got this set for the Guy in Canada I sold it to him if you need any help installing them or anything let me know i can help also get more set if needed VeeDubTDI; was this set in any way broken on your side. He claim it was and did get paid for it... Please pm me
In my installation i did not use any resistors or capacitors. I removed the plug from the tail and just shaved the pings a bit to make them fit in the cars plugs. No coding needed the back up lights are on the outside tail not the inner i had to run a cable from the inner thru the outside ones...Any idea what the Chinese loo coding number is for the BCM? That would help a lot!
Not 100% plug and play but with a bit of time i can order them from my friend in China and ship to you it takes about two weeks the set is not that expensive. The shipping is is about $134 shipped to USA so your looking around $410 for the set plus the shipping so around $544 give or take a few bucks depending on the exchange rate..That looks great, good work. @passat2012nc do you mind telling the group what a pair of these runs? Think you will be able to make them plug/play?
My phone makes it looked that way. What wire are you connecting ?That looks great, good work. @passat2012nc do you mind telling the group what a pair of these runs? Think you will be able to make them plug/play?
https://www.youtube.com/watch?v=YrRIml8hSM4&feature=youtube_gdata_player
https://www.youtube.com/watch?v=U3dKBRLSSV8&feature=youtube_gdata_player
CDS版本: ZHS 10.6.3
数据版本: 20110106
星期五,13,五月,2011,10:54:47:39956
底盘类型: 7N0
扫描: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 55 56
62 72 77
车辆识别号: LSVCD6A43BNxxxxxx
01-发动机-- 状态: 个别通讯错误1000
02-自动变速箱-- 状态: 发生故障0010
03-ABS制动-- 状态: 发生故障0010
04-转向角-- 状态: 正确0000
08-空调/加热系统-- 状态: 发生故障0010
09-中央电气系统-- 状态: 发生故障0010
10-驻车/转向辅助-- 状态: 正确0000
15-安全气囊-- 状态: 正确0000
16-方向盘-- 状态: 正确0000
17-仪表板-- 状态: 发生故障0010
19-CAN网关-- 状态: 发生故障0010
25-防启动锁-- 状态: 正确0000
37-导航系统-- 状态: 正确0000
42-驾驶员侧车门-- 状态: 发生故障0010
44-转向助力-- 状态: 发生故障0010
46-中央舒适系统-- 状态: 正确0000
4F-中央电气系统II -- 状态: 正确0000
52-乘客侧车门-- 状态: 发生故障0010
53-驻车制动-- 状态: 发生故障0010
55-氙灯射程-- 状态: 发生故障0010
56-收音调谐器-- 状态: 正确0000
62-左后车门控制-- 状态: 正确0000
72-右后车门-- 状态: 正确0000
77-电话-- 状态: 正确0000
地址01: 发动机(CEA) 标签: 无
零件号 软件: 06J 906 027 AL 硬件: 06J 907 309 A
组件: MED17.5.2 01 8498
版本: P3H06--- 序列号:
编码: 0404000324070160
服务站代码: WSC 00078 790 00193
VCID: 75EA36696547
未发现故障码。
就绪状态: 0000 0000
地址02: 自动变速箱 标签: ZHS\0AM-300-04x.clb
零件号 软件: 0AM 300 050 E 硬件: 0AM 927 769 D
组件: GSG DSG AG7 403 2325
版本: 00040034 序列号: 5ZV01005260044
编码: 0000020
VCID: 2B5ED011F383
找到1 个故障码:
006224 - 数据总线传动系: 发动机控制发出的信息缺失
P1850 - 000 - - - 间歇
故障发生环境要求:
故障状态: 00100000
故障优先级: 0
故障频率: 1
自动重置计数器: 3
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:06:51
地址03: ABS制动(J104) 标签: 无
零件号 软件: 561 907 379 B 硬件: 561 907 379 B
组件: ESP MK60EC1 H26 0105
版本: 00H26001
编码: C54BC8F6092B00FAA30B13E490190049360000
服务站代码: WSC 00078 790 00198
VCID: 21423239814F
3 个故障码已找到:
01314 - 发动机控制单元
004 - 无通讯信号- 间歇
故障发生环境要求:
故障状态: 00100100
故障优先级: 2
故障频率: 1
自动重置计数器: 68
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:06:51
故障发生环境要求:
计数: 0
计数: 14
计数: 28672
计数: 8194
计数: 40448
计数: 1024
计数: 0
计数: 0
01325 - 轮胎压力监控器控制单元
004 - 无通讯信号- 间歇
故障发生环境要求:
故障状态: 00100100
故障优先级: 2
故障频率: 1
自动重置计数器: 68
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:07:01
故障发生环境要求:
计数: 2
计数: 14
计数: 28672
计数: 16390
计数: 40448
计数: 1024
计数: 0
计数: 0
02214 - 轮胎压力警告
002 - 低于下限值- 间歇
故障发生环境要求:
故障状态: 00100010
故障优先级: 2
故障频率: 1
自动重置计数器: 80
里程: 1679 km
时间标志: 0
日期: 2002.14.27
时间: 13:04:47
故障发生环境要求:
计数: 0
计数: 32768
计数: 4096
计数: 16401
计数: 49410
计数: 0
计数: 520
计数: 0
地址08: 空调/加热系统 (J255) 标签: 无
零件号 软件: 561 907 044 B 硬件: 561 907 044 B
组件: Climatronic H01 0101
版本: 00001001
编码: 0000002102
ASAM数据库名: EV_ACClimaBHBVW411 A01001
ROD: 不可用
VCID: 162811E55801
零件号 软件: 561 907 049 A 硬件: 561 907 049 A
组件: KBT-H H08 0008
序列号: 20101216000000000006
无ASAM数据: "EV_ACClimaBHBVW411" (VW36)
找到1 个故障码:
13701376 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:52
地址09: 中央电气系统(J519) 标签: ZHS\1K0-937-08x-09.clb
零件号 软件: 5K0 937 087 N 硬件: 5K0 937 087 N
组件: BCM PQ35 H+ 011 0046
版本: BF011001
编码: 66000A3B802D1AD44008008091008B704375978870A0896401 8000200840
VCID: 408497BD6A05
零件号: 1K0 955 559 AH
组件: RLS 080910 05 54 0403
编码: 03300A
找到1 个故障码:
01038 - 中控锁过热保护
000 - - - 间歇
故障发生环境要求:
故障状态: 00100000
故障优先级: 6
故障频率: 1
自动重置计数器: 84
里程: 2198 km
时间标志: 0
日期: 2003.14.21
时间: 09:36:05
故障发生环境要求:
端子15关
电压: 12.15 V
断开
接通
断开
断开
断开
地址10: 驻车/转向辅助(J791) 标签: ZHS\3C8-919-475.clb
零件号 软件: 35D 919 475 B 硬件: 3T0 919 475 C
组件: PARKHILFE PLA H08 0203
版本: -------- 序列号: --------------
编码: 30810F
VCID: 3162C279D1AF
未发现故障码。
地址15: 安全气囊(J234) 标签: 无
零件号 软件: 56D 959 655 硬件: 56D 959 655
组件: VW10Airbag003 H01 0001
版本: -------- 序列号: 003JK2T004NE
编码: 000000000000000000000000000000003033
服务站代码: WSC 64250 381 2056031
ASAM数据库名: EV_AirbaVW10BPAVN750 A01026
ROD: 不可用
VCID: F6E8B165F841
无ASAM数据: "EV_AirbaVW10BPAVN750" (VW36)
未发现故障码。
地址16: 方向盘(J527) 标签: ZHS\5K0-953-569.clb
零件号 软件: 1K5 953 507 T 硬件: 5K0 953 549 B
组件: Lenks.Modul 008 0080
版本: -------- 序列号: WHRPIturHHHI?
编码: 088A140000
服务站代码: WSC 00078 790 00171
ASAM数据库名: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 42809DB56409
MFL:
零件号 软件: 56D 959 537 硬件: 56D 959 537
组件: E221__MFL-TK6 H06 0022
序列号: 70000000000000130396
编码: E20000
未发现故障码。
地址17: 仪表板(J285) 标签: 无
零件号 软件: 56D 920 880 硬件: 56D 920 880
组件: KOMBI H06 0307
序列号: 00000000000000
编码: 131E01
ASAM数据库名: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: EAD09515BCF9
找到1 个故障码:
12648448 - 由于信息缺失而造成功能受限
U1111 00 [008] - -
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:51
地址19: CAN网关(J533) 标签: ZHS\7N0-907-530-V2.clb
零件号 软件: 7N0 907 530 D 硬件: 1K0 907 951
组件: J533 Gateway H35 0614
版本: H35 序列号: 220710F1002291
编码: 461000
服务站代码: WSC 00078 790 00176
VCID: 3162C279D1AF
找到1 个故障码:
01314 - 发动机控制单元
004 - 无通讯信号- 间歇
故障发生环境要求:
故障状态: 00110100
故障优先级: 2
故障频率: 1
自动重置计数器: 67
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:06:52
地址25: 防启动锁(J334) 标签: ZHS\5K0-920-xxx-25.clb
零件号 软件: 5K0 953 234 硬件: 5K0 953 234
组件: IMMO H06 0307
序列号:
编码: 000000
ASAM数据库名: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD09515BCF9
未发现故障码。
地址37: 导航系统(J0506) 标签: 无
零件号 软件: 56D 035 682 硬件: 56D 035 682
组件: RNS-MID H50 0878
序列号: VWZ6Z7K4336083
编码: 00000442040000A4000B
ASAM数据库名: ------------------------- ------
VCID: E7D6EC21AFEB
未发现故障码。
地址42: 驾驶员侧车门(J386) 标签: 无
零件号 软件: 56D 959 701 硬件: 3C0 959 793 B
组件: TUER-SG FT 002 0503
版本: 13110009 序列号: 0001492978
编码: 0404F5
ASAM数据库名: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: EED899058011
Slave Driver:
零件号 软件: 561 959 811 硬件: 561 959 811
组件: J388__TSG_HL 002 4491
序列号: --------------------
编码: 000000
找到1 个故障码:
68108 - 由于信息缺失而造成功能受限
U1111 00 [008] - 电路有故障
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:51
地址44: 转向助力 标签: ZHS\1Kx-909-14x.clb
零件号: 1K0 909 144 J
组件: EPS_ZFLS Kl. 196 3001
版本: 00H17000
服务站代码: WSC 00078 790 00182
VCID: 3162C279D1AF
找到1 个故障码:
01314 - 发动机控制单元
004 - 无通讯信号- 间歇
故障发生环境要求:
故障状态: 00100100
故障优先级: 3
故障频率: 1
自动重置计数器: 67
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:06:51
故障发生环境要求:
电压: 11.25 V
DU
温度: 14.0*C
发动机转速: 1498 /min
车速: 0.0 km/h
车速: 0.0 km/h
计数: 0
地址4F: 中央电气系统II (J520) 标签: 无
零件号 软件: 7N0 907 532 硬件: 1K0 907 951
组件: EZE_2 H35 0614
编码: 01030108
VCID: EFE68401871B
零件号 软件: 561 959 591 硬件: 561 959 591
组件: J245 P05 FFD7 H07 0004
编码: 181100
零件号 软件: 561 919 204 硬件: 561 919 204
组件: Analoguhr X06 X002
未发现故障码。
地址52: 乘客侧车门(J387) 标签: 无
零件号 软件: 56D 959 702 硬件: 3C0 959 792 B
组件: TUER-SG BT 002 0503
版本: 15110009 序列号: 0001493202
编码: 0404F4
ASAM数据库名: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: EFE68401871B
Slave Passenger:
零件号 软件: 561 959 812 硬件: 561 959 812
组件: J389__TSG_HR 002 4491
编码: 000000
找到1 个故障码:
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:51
地址53: 驻车制动(J540) 标签: 无
零件号 软件: 56D 907 801 A 硬件: 56D 907 801
组件: EPB-4 H03 0004
版本: -------- 序列号: 00000000000332
编码: 0F3C55
ASAM数据库名: EV_ParkiBrakeTRWVW411 002007
ROD: 不可用
VCID: 29522A19F97F
无ASAM数据: "EV_ParkiBrakeTRWVW411" (VW36)
5 个故障码已找到:
333568 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:50
334080 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:50
327936 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:50
331264 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:50
331520 - ROD - 未知错误代码
故障发生环境要求:
故障状态: 00000001
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
日期: 2002.14.23
时间: 09:06:50
地址55: 氙灯射程 标签: ZHS\5M0-907-357.clb
零件号 软件: 5M0 907 357 D 硬件: 5M0 907 357 D
组件: AFS-Steuergeraet 0149
版本: 00H04000 序列号:
编码: 7472341
VCID: 356AF66925C7
零件号: 3TD 941 329
组件: AFS-Lst.-Modul l 0002
编码: 00000114
零件号: 3TD 941 329
组件: AFS-Lst.-Modul r 0002
编码: 00000114
找到1 个故障码:
01314 - 发动机控制单元
004 - 无通讯信号- 间歇
故障发生环境要求:
故障状态: 00100100
故障优先级: 6
故障频率: 1
自动重置计数器: 67
里程: 1672 km
时间标志: 0
日期: 2002.14.23
时间: 09:06:51
故障发生环境要求:
电压: 11.08 V
车速: 0.0 km/h
ABS 1
地址56: 收音调谐器(J0506) 标签: 无
序列号: VWZ6Z7K4336083
VCID: E7D6EC21AFEB
未发现故障码。
地址62: 左后车门控制
无法进入
地址72: 右后车门
无法进入
地址77: 电话(J738) 标签: ZHS\1K8-035-730.clb
零件号 软件: 1K8 035 730 D 硬件: 1K8 035 730 D
组件: Telefon H08 6900
版本: 00008000 序列号: 00000A07781246
编码: 412120
VCID: 2A50D515FC79
未发现故障码。
结束 --------------------------------------------------------------------[/code
Credit goes to wolfsburg_de[/size]
That is what im talking about ... I sold a set to Jimmy had he got this working .. Can you tell me know you set the wiring so that i can mod my adapters....
Does the LED s flick a bit or not a all now?
That extra wire goes to the control unit ?
