I have an 06 Jetta that will not blow hot air out of the face vents. By face I mean the dash vents. Once I switch to floor its fine. I ran the VAG on the HVAC and noticed that while monitoring outlet blower temperature its a flat line 84C. So while on the dash/face setting the blend door controller slowly integrates down or closed (this is where I need help because I don't have any information on the control logic) and I am assuming that this is to move the outlet blower temp down which it can't because it has failed?. Watching the same control for the floor vent shows the floor blower temperature indication modulating and changing the temperature control input which has an effect on the blend door controller and the actual temperature. SO....
I am assuming that the outlet blower temperature indication has failed and is flat lining 84C. Does anyone know where this instrument is located within the system? Is there another name for it? I appreciate any help and apologize if this has been discussed in another thread.
