TwistedElvis
Its almost time to do my rear brakes on my 15 sportwagon and wondering what size the rotors were, and if there are any upgrades people are doing?
why do you want to upgrade? Vanity or for performance?
I upgraded my fronts to the 312mm purely for the vanity of having the larger brakes. I didnt notice any real world difference that couldnt have been explained by just doing a better pad. I found someone on vortex who was upgrading their GTI to an R brake size and I bought the red GTI carrier and used my same caliper.
A quick look and there are 2 options for rear disk size, a 253mm and a 272mm rear. Im betting the Alltrack/GTI (non PP) and GLI all used the larger size and we lowly GSW get the smaller, solid disks. If the swap is anything like the front (non performacepack) then you can reuse your caliper and get the larger caliper carrier to accommodate the new larger disk. The caliper is the same and you would then order the new size pad and disk from the GTI/GLI/Alltrack. Bolt and offset will be identical.
Resize this photo, please.
did you ever get this to work?Interestingly enough, I have a set of GTI power pack brakes (calipers and carriers) in my possession right now. They fit 310x22 mm rotors. I also have the matching rotors. This setup will bolt on but the brake & e brake lines come from the opposite side (top/bottom). It means rerouting the e-brake cable and needing a brake line that's 2-3" longer to reach.
The Golf has 253x10mm rears, like the GSW presumably. I didn't even think of trying our stock caliper with the power pack carriers. If I have time this weekend I'll try it out and let you guys know.
If our caliper will bolt up to the power pack carriers the next problem would be finding 310x10mm rotors. The 310 mm rotors that fit various VAG cars are all 22mm wide, probably too wide for our calipers. My assumption is this will put a stop to my whole experiment but I have everything here to try it out.
But... Since the power pack carrier will bolt up so too should the non powerpack carrier. IF the stock caliper will bolt up to the non powerpack carrier as well a rear upgrade is just as easy as the front (new carriers with new rotors).
Sent from my ONEPLUS A6013 using Tapatalk
