Old November 11th, 2018, 15:03   #1
vincej
Default 2014 DSG oil change
This one looks different from my 2013. I need access to the DSG oil filter and can't separate the air filter box from the battery tray. The two must be separated for me to be able to get the battery tray out. I have removed the torx screws and the air horn but the two are still stuck together at the bottom of the air filter box by what looks like two plastic plugs. I don't want to break them.Any suggestions? Thanks.
vincej is offline   Reply With Quote
Old November 11th, 2018, 15:21   #2
vincej
Got it by putting the two front 10 mil head bolts in the battery box and pulling up on the air filter box.
Old November 19th, 2018, 18:44   #3
gmcjetpilot
gmcjetpilot's Avatar
The two can be fused together. I have had same issue. I did not want to break anything...
I don't remove the air box and tray. I just shove it out of the way as much as needed, to access DSG filter.
Some people even get at by just tilting the battery over. Saves battery and tray removal.
https://www.youtube.com/watch?v=vSHK7Pj5rjA
I tried top fill this time and like it. It did not take that long and a little less mess than bottom full and dealing with the fill tool, but either way works.
gmcjetpilot is offline   Reply With Quote
Dsg oil change jodiibe Fuels & Lubricants 72 November 19th, 2015 20:57
Oil Change Write up- 2014 Passat SE 6MT sdeck VW Passat Family (NMS and B7) TDIs (2012+) 19 October 2nd, 2015 20:14
Should I change the oil on a 2014 just off the lot? samak Fuels & Lubricants 25 April 14th, 2015 07:42
Oil Change on 2013 - 2014 New New Beetle Conv TDI DouginNC VW Beetle 2012+ 9 March 5th, 2015 07:48
2014 Passat TDI Oil Change Pricing sowegatdi VW Passat Family (NMS and B7) TDIs (2012+) 14 January 11th, 2015 08:21
Page generated in 0.13564 seconds with 11 queries
[Output: 57.78 Kb. compressed to 52.34 Kb. by saving 5.44 Kb. (9.41%)]
