rach
I'm new to this forum and am hoping to get some advice on a bad situation I find myself in.
My 2002 TDI Golf was having a problem with progressively diminishing power/acceleration. My regular local mechanic, who does not have any special knowledge of diesels, thought it might need a new turbo, but suggested I take it to the dealer for diagnosis.
Took it to the dealer. Had them change the oil while it was there. The diagnosis they gave was that the EGR valve and intake manifold were caked with carbon and needed to be replaced.
Took the car back to my local guy, who ordered the EGR valve and said he'd try to clean the manifold, instead of replacing. He called the next day to say: Bad news, your engine blew up. At his point he says he had: Removed and cleaned the EGR valve, removed and cleaned the pre-warm-up heater, removed and cleaned the intake manifold, and put all those things back in the car. He took it out on a short test drive when the engine died. He said there was a loud crack.
Seems like between the dealer and this mechanic, something must have been done wrong, since this engine would not be likely to die of natural causes at 135,000 miles. The car has been towed the home and I'm planning to tow it to Wheaton Service Center in MD (found that shop in the list of recommended mechanics on this site) next week, when they can fit it in. I asked them to first check it out with an eye toward what might have gone wrong, then let me know what we'd be into if we are going to get everything fixed.
Other info that may be pertinent:
Manual transition with original clutch
Timing belt replaced at about 90K
Used Mobile One oil
At around 110K, engine started to use some oil and I'd top it off between changes
Anyone have any advice for me? What would you do in this situation?
Thanks!
Rachel
Used Mobile One oil
Thanks!
Rachel
