fase2000TDI
Hey TDIclub,
I've been apprenticing with a trusted TDI mechanic for about 10 months now, and have owned a TDI for 6 years. In this time I've learned a lot, more than I ever thought possible. I've learned proper working habits if I only take on work I can perform correctly.
I'm available in Glocester, RI to service your TDI's. I'm available for:
*Timing belts AHU/IZ, ALH, BEW & BRM (98-2008)
* ALH/AHU/IZ head replacement (yes, I've done them!)
* brakes & replacing brake fluid
* injector nozzles
* Alternator & alternator pulley replacement
* Thermostats (A3 and A4)
* Suspension & lift kit installs
* rear axle bushings
* power steering racks
* intake manifold cleaning
* replacing cam followers (attn 200K+ TDI owners needing a timing belt done)
* glow plugs diagnose & repair
* timing adjustments
* Automatic transmission fluid & filter changes, Manual transmission gear oil changes
* ABS Sensor replacement
* routine maintenance
* diagnosing & repairing low power issues
* Free vagcom diagnostics
* & more!
If I can't fix an issue, I won't throw parts a problem. I don't charge for my time if I can't diagnose an issue. I have a decent selection of parts on hand, and carry all the fuel/oil/air/cabin filters for 99.5~2010 cars. I only do quality work, and I keep my rates low.
Available for service all day Friday thru Sunday. Monday - Thur after 12:00pm
Now performing timing belts!
I'll see if some of the people I've helped would be willing to post. I also welcome feedback of any kind.
Jeremy Crafts
jeremytdi@yahoo.com
401-919-0466
1319 Putnam Pike, Glocester, RI
* injector nozzles
* & more!
Jeremy Crafts
jeremytdi@yahoo.com
401-919-0466
