Old November 16th, 2018, 11:58   #1
MP517PRCT
Fuel Economy: ~45mpg in the JSW, ~56 in the '05.5
Default Walked away from this deal...
I am searching for a replacement for my '09 JSW 6M that I am turning in on 12/6. I drove 2-1/2 hours today to look at a '12 JSW 6M for $12k. The price was good, but I was turned off by the high-pressure sales job.
I took the car for a test drive, stopped in a parking lot, hooked up VCDS and ran a scan. I am posting the results below.
If anyone wants to know where to find the car, PM me. MODS - I am NOT the seller!!! I have no connection to the seller, I am posting this as a public service. I am with holding the dealership's name, to protect the innocent!
Caveat Emptor, someone (previous owner?) scratched "F*CK YOU" into the touch screen on the radio.
Friday,16,November,2018,12:11:31:50183
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: 3VWML7AJ6CM681983 License Plate: 0000
Mileage: 52150km-32404mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
VIN: 3VWML7AJ6CM681983 Mileage: 52150km-32404miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 2F43EE9DBED94B327C-807A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492A00FB881406EC921C0042B70000
VCID: 7DDF04D5E43569A2BE-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 52038 km
Time Indication: 0
Date: 2018.10.30
Time: 10:43:13
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 50432
Count: 0
Count: 765
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00120
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 00217D219BC7044AD5-8054
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1F802F3EC4008800C17000004449000086535D056064 8020200040
Shop #: WSC 04024 003 1048576
VCID: 3957D0C5B09D9582D2-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 17031 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1J5G%
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FA3BEDDA6B9BBB2EC-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000038TR00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2B626269ZZZ.
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2F03026BZZZX
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME24713B2BZZZM
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME57043D2BZZZR
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME5848032BZZZH
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5B147129ZZZH
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KKL0017S
Coding: 108A140000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72C527E9A56B26DAD3-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0098799
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 3041EDE16BE754CA65-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 06031201291115
Coding: 352002
VCID: 3D5FC4D5A4B5A9A2FE-8068
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RG78506
Coding: 0000002
VCID: 7EDD03D9293372BAA7-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AF53F898DBBEE1A6B-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661541126
Coding: 010000
VCID: 29770085403D2502A2-807C
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 354FDCF55C8571E236-8060
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FC32E9DBE590B323C-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004256103
Coding: 0004B4
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5C99695157EF80AAE9-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006339132
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3265600
Coding: 01000400040007
VCID: 63EB52AD6291BF52A8-8036
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 111
Mileage: 52023 km
Time Indication: 0
Date: 2018.08.15
Time: 06:30:43
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007661751402
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 277306BD5E291372B4-8072
End-------------------------(Elapsed Time: 02:09)--------------------------
MP517PRCT is offline   Reply With Quote
Old November 16th, 2018, 17:33   #2
gmcjetpilot
gmcjetpilot's Avatar
The scan is good. ABS looks like it was related to tire pressure. radio always shows up if you don't have Sirius XM.
You did not buy it because the salesman pissed you off? Interesting approach. I would never buy another car, house again because all salesman piss me off.... ha ha. High pressure is what? Good car, good price you thought, tell them to shut up and let you look it over. Of course a pre-purchase is not a bad idea. I would do that. If they balk at that, then I would be likely to walk away.
gmcjetpilot is offline   Reply With Quote
Old November 16th, 2018, 20:57   #3
Ol'Rattler
Ol'Rattler's Avatar
So why exactly did you bother to post a scan with no problems to a car that you did not own and make who the seller is some mysterious secret? None of your post makes any sense. It might have been more proactive to bend the seller over and done a scan on him and posted that.
It just kills me that some people think VCDS is sort of miracle tool when they don't understand it's purpose in automotive diagnosis.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old November 17th, 2018, 14:34   #4
MP517PRCT
My question is why do you think that this forum has to be "The Jerry Springer Show?" I'm not trying to harm or help the dealer. I posted this in case someone else might be in the market for a 2012 JSW 6MT. I did not post the name of the dealership because I am not a shill for them, nor am I trying get some weird sort of revenge. Quite frankly, I bet if you took the time to copy and paste the VIN into google, it would probably bring up the car's listing on the dealer's website.
Just because I'm not buying this car doesn't mean that I'm implying that there is anything wrong with it or that dealer is trying to pull some underhanded shenanigans.
I scanned the car for my own piece of mind. Later, I decided not to purchase said car and decided that rather than just delete the scan, I would post it here. In that way, I might just be able to "pay it forward" to a fellow tdiclub member who is car shopping for a similar vehicle and doesn't have access to VCDS.
Guess no good deed goes unpunished!!!
P.S. - Diagnostic Tools are useful, even with the diagnosis is "good health"
Old November 17th, 2018, 15:14   #5
BamaB4S
BamaB4S's Avatar
Fuel Economy: 42/47/52 mpg
Here is the dealer and car: https://carsindex.com/2012-Volkswage...6/Details.aspx
BamaB4S is offline   Reply With Quote
Old November 18th, 2018, 13:20   #6
Ol'Rattler
Ol'Rattler's Avatar
Originally Posted by BamaB4S View Post
A very important teeny tiny detail that should have been in the first post. How would this detail be relevant to Jerry Springer?
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old November 19th, 2018, 13:47   #7
cygtoad
Just bought one of these (emissions fix made) for the same price and mileage, but without the sunroof. If you really want it, go back and get it. I have no regrets. Well now you are making want a sunroof, but other than that, no regrets.
cygtoad is offline   Reply With Quote
think I should have walked away from this one (blue smoke starts) harry3 TDI 101 25 October 30th, 2014 14:07
HELP ME READ CARFAX REPORT, Good deal? Bad deal? Dashley143 VW MKIV-A4 TDIs (VE and PD) 7 April 18th, 2012 06:54
Part 2: She walked away kburrell Atlantic Canada 13 July 19th, 2007 09:17
We walked Away kburrell Atlantic Canada 23 July 18th, 2007 12:09
He walked away... Fyrman Atlantic Canada 7 June 26th, 2007 15:43
Page generated in 0.09786 seconds with 13 queries
[Output: 96.60 Kb. compressed to 84.55 Kb. by saving 12.06 Kb. (12.48%)]
