Europe based
Can anyone please help me help my mechanic. Before xmas my car started to judder when i put the foot down. it was ok next day. snag came back and thinking it was dirty diesel. I changed the fuel filter and added fuel additive to flush the injectors. was ok for a day then engine judder came back. not happy at all. I took it to mechanic and airflow mass meter showed a fault. replaced mass meter fault cleared but engine still juddering with bit more smoke.Mechanic felt best to go to vw.
Then I took it to another mechanic who is a mate and a full time vw mechanic. He felt it was the fly wheel in trouble vibrating and knocking the timing hence the smoke. Flywheel replaced as well as the clutch little bit better but still juddering ( the dash board shaking a bit) and still not firing all cylinders sort of thing.Starting to get very expensive.....
My mate then got special fuel pressure gauges from VW and all fuel pressures checked out ok. Also inlet fuel air manifold I think he said was bit dirty and cleaned. still the same
He then drained all the fuel and the tank. Put in known clean diesel. no good.still the same.
He also swapped 2 of the injectors between cylinders to see if and change in the vibration and misfire type of thing. did not seem to be any change.
The last thing he is going to try is to check the timing that requires a special tool he says. After that he says he has to give up...
If anyone has any ideas on this one . PLEASE please come back to me..
Computer is showing no fault or miss fire. my wife is expecting in 4 weeks. need car sooon
rgds
Bio Boy
rgds
Bio Boy
