Old January 17th, 2005, 13:51   #1
landon11
Default Finally got VAG-COM
to do the nozzle swap, now what other interesting things can I do with it?
Thanks.
landon11 is offline   Reply With Quote
Old January 19th, 2005, 10:23   #2
onehotspud
onehotspud's Avatar
Fuel Economy: 59/45/36
Default Re: Finally got VAG-COM
You might want to post this question in the OBD Scanners section.
http://forums.tdiclub.com/postlist.p...mp;Board=UBB13
From what I have seen though, questions like that don't get much of a responce. There are stickies at the top to help out with things. Ross-Tech's site has some good things. Poke around there. Stuff like unlocking all the doors when you pull the key out of the ignition and changing the clock to 24 hour instead of 12. Removing the seatbelt chime (my favorite). Try looking around the OBD Scanners sections as well. There is a lot of info already in there. Make sure that you're looking at more than just recent posts.
onehotspud is offline   Reply With Quote
Page generated in 0.12222 seconds with 10 queries
[Output: 48.14 Kb. compressed to 44.26 Kb. by saving 3.88 Kb. (8.06%)]
