Old September 27th, 2019, 08:59   #166
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
No recommendations, but I believe you can slow prime that thing just using the in tank pump. Maybe hook up a battery charger and don't overheat the starter.
See what others have done-
VW TDI Search Engine
Old September 27th, 2019, 09:14   #167
Tom Rose
Thanks Bob, but reviewing all the "HOW TO" videos many say I can do damage to the fuel pump w/o priming. I've read where some pour fresh diesel in the canister, install new filter, & claim they're good to go, but ?
Tom Rose is offline   Reply With Quote
Old September 27th, 2019, 10:00   #168
BobnOH
not-a-mechanic
Yes, research, it can damage, guessing maybe you don't use the starter or disable starting?
Old September 27th, 2019, 11:25   #169
JSWTDI09
JSWTDI09's Avatar
Originally Posted by Tom Rose View Post
can anyone recommend a scanner that will power up the fuel pump when I change my fuel filter ? (2011 JSW TDI) I don't own a laptop at this time. Looked on Amazon & saw some, not sure if / which to buy. Thanks guys, my money is a little tight right now
Any VW specific scanner that can do "basic settings" will work. Search for this term in the description. VCDS is, undoubtedly, the best, but it's not cheap. I know that ODBeleven can do it but it requires an Android device. I'm sure that there are also others, but I am not really familiar with them.
Have Fun!
Don
1966 MGB Roadster (just for fun)
JSWTDI09 is offline   Reply With Quote
Old September 27th, 2019, 12:05   #170
Tom Rose
Thanks Don !!!!!1
Old September 27th, 2019, 20:44   #171
jef@rosstech
Associate Ross-Tech Vendor
We have kits starting at $199, just add a Win7 or newer laptop. The software isn't locked down to a computer, so one could barrow a friend's laptop if needed.
And the laptop doesn't have to be a power house. If you've seen any of the poorly produced Ross-Tech videos, I'm using a sub $300 Asus netbook to run VCDS on and screen capture. Here is a relevant example of a sub standard video:
https://www.youtube.com/watch?v=VZYJjMNfQ-I
Bonus points if you find the cat judging you.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old September 28th, 2019, 07:59   #172
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Nothing required other than when you have dropped the new filter into place use either Diesel, PowerService or any other diesel fuel additive you have on hand to fill the housing to the brim. Then close it up and restart your engine.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.Scangauge II
Jetta_Pilot is offline   Reply With Quote
Old September 30th, 2019, 09:46   #173
Jetta_Pilot
Here is a Youtube link for a fuel filter change, easy peasy !
I have a plastic shopping bag handy to drop the used filter into after it has drained most of the Diesel off.
I have not found it necessary to use a VCDS or prime with the fuel pump since before closing the filter I add and fill the filter housing with either PowerService, Diesel or any other Diesel fuel additive I have handy.
Old October 1st, 2019, 12:33   #174
Jetta_Pilot
Filter change
https://www.youtube.com/watch?v=0kbIAwF2uvA
Just changed my fuel filter today from a "MANN" to something else. What a PIA to remove the MANN filter. There is a ridge around the bottom of the filter which made it very difficult to remove.
My replacement does not have that.
I filled the housing including the center of the filter with PS.
Closed it up and with my KESSY just turned on the ignition for 30 seconds before I started the engine. Not even a sputter, started right up.
Page generated in 0.14065 seconds with 10 queries
[Output: 92.07 Kb. compressed to 78.59 Kb. by saving 13.48 Kb. (14.64%)]
