Old July 20th, 2013, 10:58   #1
SledDawg2
Default VCDS Software out of date
I have VCDS with the HEX-COM-CAN interface.
Software 11.11
Whenever I start my VCDS I 'm getting a warning that my software is out of date.
I only use this on my personal car ond once in a while another family member may ask me to check their VW for a CEL.
The problem is my lap-top does not have a modem and upgrading is not a straight forward procedure.
For my needs I'm happy with what I have.
How can I get rid of the peskey warning without having to upgrade the software ?
SledDawg2 is offline   Reply With Quote
Old July 20th, 2013, 12:19   #2
TDI_Dan
TDI_Dan's Avatar
Download from another machine and install on a flash drive? You essentially do an over the top refresh/update. It will ask if you want to update the USB driver. That us optional but doesn't seem to hurt anything either if you do it. If you bought the legitimate cable, check with them. Does it have a cd rom drive? USB ports?
TDI_Dan is offline   Reply With Quote
Old July 20th, 2013, 12:37   #3
SledDawg2
Default Vcds
...Does it have a cd rom drive? USB ports
No USB port just a floppy slot like this ....
5.25" floppy
Old July 20th, 2013, 12:46   #4
Shawnz
Fuel Economy: 45 MPG
laptop with 5 1/4 floppy? Now I'm intrigued.
Sounds like an old lug-able in a sewing machine - like box.
2006 Mercury Montego Premier (FWD, 6 Sp auto)
2002 VW Jetta GLS TDI - 5sp swap, VNT 17/22, Bosio PP764, SBC Stg2 Daily SMF Clutch, Malone Stg 5, DG RacePipe, EGT / Boost Gauge, Evo Atlas skid, Curt hitch
Shawnz is offline   Reply With Quote
Old July 20th, 2013, 12:59   #5
SledDawg2
Years ago my father bought this...
It has a newer type video card and display output.
A printer card has also been added
Old July 20th, 2013, 14:27   #6
Vince Waldon
Vince Waldon's Avatar
Under "Options", in the "check for free updates" pull-down, select "do not check for updates".
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old July 20th, 2013, 18:13   #7
Keithuk
Keithuk's Avatar
The latest version is Release 11.11.6 but you will need someway of getting it on your laptop.
If you click the X in the top right corner of that out of date message you can carry on using your current version.
Golf GTD (170) 2010, 5 Door, Shadow Blue, Flat Tyre Indicator, Service Plan, Basic Protection Pack +VCDS.
Keithuk is offline   Reply With Quote
Old July 24th, 2013, 13:25   #8
SledDawg2
I've made this change under the Options section.
But I still get the prompt that my software is out of date.
Old July 24th, 2013, 13:27   #9
Vince Waldon
Best bet might be to escalate to Ross-Tech directly... that's what Tech Support is all about and they have a history of actively wanting to know when there are bugs out there.
Old July 24th, 2013, 17:35   #10
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
It's not checking any more, but it has already checkED, and the message will remain.
If you still have the install on floppy, uninstall from the machine, reload to the machine from the floppy, and turn off the check before it 'knows' there's a newer version out there.
Without a modem or connection how did it discover that there is a newer version than the one installed?
Svante Arrhenius 1896
Old July 25th, 2013, 09:26   #11
KERMA
KERMA's Avatar
what is your operating system?
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Niels Bohr
KERMA is offline   Reply With Quote
Old July 26th, 2013, 04:39   #12
TDI_Dan
TDI_Dan's Avatar
I think it may use a timed expiration (?). It sounds illogical but, my laptop prompted me to update and I had no Internet connection at the time.
Old July 26th, 2013, 04:42   #13
TDI_Dan
TDI_Dan's Avatar
Lol. I had an Atari 800 that used 5.25" floppies. No hard drive. Neighbor had a Commodore 64. It had cassette and floppy.
Old July 26th, 2013, 04:51   #14
TDI_Dan
TDI_Dan's Avatar
5.25" floppy
Pics please! Preferably with system on and running. I thought the 5.25" was dead around the end of Windows 3.1. ... And in a laptop???
I think you're pulling our chain. 😬
Old July 26th, 2013, 08:27   #15
Powder Hound
Powder Hound's Avatar
Yikes that is old. I did have a laptop that as recently as 15 years ago used 3 1/2" floppies, but it was mostly because its usb ports were dead - no usb drivers from windows 98.
manufacture date bockegg VW MKV-A5 Golf/Jettas 11 April 12th, 2015 21:53
ECU swap - immobilser delete - just by software change in VCDS? bhodgkiss TDI Power Enhancements 22 May 11th, 2013 15:16
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 11:15
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 21:21
manufacture date? BatmanMN_M TDI 101 12 October 29th, 2003 16:49
Page generated in 0.17306 seconds with 11 queries
[Output: 131.44 Kb. compressed to 109.51 Kb. by saving 21.93 Kb. (16.69%)]
