Old April 8th, 2009, 10:01   #1
jjohnv
Fuel Economy: 44 to 48 usual 52 best
Default vag-com finally
I got one, finally, install vmware fusion then xp on my powerbook, seems to run perfectly.
I advanced the timing through adaptation, exactly what I couldn't get another tdi owner to do, seems to run fine.
Questions, the other tdi owner kept messing with the injected fuel quantity, keep saying this would help, it made the car more thirsty.
WHat number should I put in for adaptation? I think it was 32690 and I changed it to 32645, again seemed to run well.
I am not interested in racing or being a motorhead. I have my motorcycle if I really want to go fast. so what number should I put to optimize for economy?
Thanks in advance.
John
jjohnv is offline   Reply With Quote
Old April 8th, 2009, 16:30   #2
jjohnv
0 replies? really?
Old April 9th, 2009, 02:17   #3
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default posting
Either post in Economy forum or OB II forum-might get answer faster.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2020
A4 Limp Mode,A4 tech.com/index.php/Category:Fault_Codes"]Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Page generated in 0.12670 seconds with 10 queries
[Output: 53.60 Kb. compressed to 48.42 Kb. by saving 5.18 Kb. (9.66%)]
