kjgraynh
Great Forum: First time I didn't find my answer searching existing threads! Took my 2010 Jetta to dealer for warranty repair of "Exhaust valve stuck open" (code P047 at 112,000 mi). Since it was due I asked them to do state inspection. They then say both mirror turn signals are not functioning, of course they want $334. Took it home and scanned with VAGCOM--it says both door controllers failed about 4000 mi ago, with exactly same time code and mileage. I found that the coding no longer included the exterior mirror turn signals, so I checked the turn signal box and hit "Do it", then got "Coding Accepted", but no luck, no signals. Any ideas???
VAGCOM Log File:
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000930868
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 277327ED5EBC8320411
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 3C0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004921870
Coding: 000494
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 180497 km
Date: 2046.14.26
Time: 15:54:21
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000913383
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW36.rod
VCID: 287124D153A28C5848B
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 3C0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004928302
Coding: 000494
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 180497 km
Date: 2046.14.26
Time: 15:54:21
VAGCOM Log File:
Coding: 0004B5
Slave Driver:
Coding: 000494
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 180497 km
Date: 2046.14.26
Time: 15:54:21
Coding: 0004B4
Slave Passenger:
Coding: 000494
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 180497 km
Date: 2046.14.26
Time: 15:54:21
