Recently purchased a 99.5 MK4 jetta. I was told the VNT actuator was stuck and needed to be cleaned. I took the turbo off, cleaned the VNT rod and lever system, cleaned the vane assembly and machined backing plate (on the exhaust side), and reinstalled the whole package. Neither the VNT actuator nor the vanes moved before the cleaning. The ring a vanes moved freely when placed back on the exhaust manifold end of the turbo before the outboard end of the turbo was reinstalled, and once it was, the rod moved freely as well. Much to my dismay, i dont think the turbo is spooling up at all. I don't feel any added power at any rpms. I suppose its possible that the VNT actuator lever could have slipped out of the notch in the ring that controls the vane geometry during reassembly, but it felt like it mated fairly smoothly. I would think that even if the vanes did not move freely, the turbo would still kick in at some point?? any ideas on how to test if the vacuum chamber or vacuum lines are in working order, or what I should be checking? I saw that in some cases the MAF was a problem...afraid to say it, but I dont know what this does. also, when i examined the exhaust turbine, the lower edges of the blades appeared to be pretty significantly worn, and were no longer a straight edge. how concerned should i be??
thank you in advance for any information....or for just reading through the whole post!!!!
