JohnJTDI
Need to replace the drivers side cv joint; plan to replace the entire axle. Question- where to I find a non-Chinese axle, and do I go new or reman?
Asia means China, or not neccesarily so??I'm about to replace the axles on my new-to-me '05. I'm doing this time what I've done a few previous: new axles. Not re-manufactured, but new.
I've had more than a few re-mans that were nothing more than re-greased, many that were not re-assembled correctly (retaining clips replaced by thinner snap rings, thrust washers installed upside down) and the new ones are actually lower priced than the re-mans even after the core exchange of my dead ones. They are so low priced (<$80 each) that I can't imagine that they are from anywhere else but Asia, but my past experience is that they aren't cheaply made.
Quality? I've not have problems with any of the new axles, but I have with nearly every one of the re-manufactured ones.
"Lifetime warranty" doesn't cover down time and towing and labor. Your cheap axle broke? Here's another one exactly the same, Good luck getting that to last any longer.
Was this joint as it came out or have items already been removed? The thrust washer and retaining clip don't appear to be present or not correct for a VW axle.I have had bad ones right out of the box and I have had good ones that lasted for many years. All have been rebuilt VW ones, complete with the VW numbers and stampings on them. I understand all they do is swap the parts and reboot them, but that's fine.
I have no idea to your questions since this was a rescue when the joint blew apart driving down the road. I received a call earlier in the morning about a B4 making noise and upon description I thought it was probably a CV shaft or wheel bearing. The owner thought it was a wheel bearing. 1/4 mile from his house it let go and he needed a tow.Was this joint as it came out or have items already been removed? The thrust washer and retaining clip don't appear to be present or not correct for a VW axle.
It's this type of shoddy re-assembly that caused me to quit using re-man assemblies. The defects in workmanship (probably provided temporary day-laborer in a US location) negates whatever quality might have remained in worn components. The weakest link syndrome...
Where do u get the parts to rebuild??These axles are SO EASY to rebuild yourself, LOL... you guys crack me up.
That is one of the greatest advantages that a Volkswagen has over virtually every other brand. We can buy good, quality, reasonably priced parts brand new for these (joints, boots) and they come apart super easy. I'll take an original GKN-Lobro drive axle with half a million miles on it over a brand new Chaxle any day. Because I can rebuild the original and make it as good as new.
Plus, you can also swap joints on the axle (side to side) so after 1/4 million miles you get to start with a fresh surface inside.
I'm usually with you when it comes to Chinese parts, but I've put 90,000 miles on a $40 axle from Autozone with zero issues. I've actually never had an CV fail (OEM or otherwise) that didn't have a torn boot/contamination.Need to replace the drivers side cv joint; plan to replace the entire axle. Question- where to I find a non-Chinese axle, and do I go new or reman?
Driver axle is solid, only the passenger side is hollow.Not being the original owner and not knowing the service history,, was the original driver's side axle solid or hollow?
If you're not satisfied with the new axles you got the simplest thing to do would be to swap outers, repack and reboot.Thanks once again for your help. I am doing the VR6 5 lug swap as part of a B4 refresh that's been going on for longer than I could have ever imagined.
From what I can tell from looking at the donor car axles, the driver's side is OEM. Outer boots have VW markings and VW part #'s on them, no VW part # stamped on the axle itself. It is solid and relatively small diameter compared to the other side.
The passenger side is larger diameter and hollow, just like my old TDI axle. It appears to have been rebuilt by a company called Interparts. Their name is stamped on the outer CV boot.
Today, I thought that I could speed up things by removing all axle unknowns and start with new. Picked up a set of CarQuest new axles, total cost after 30% online discount was about $100,, and a $20 Speed Perks reward for upcoming NiCopp brake line buy.
Both of these new axles are same diameter, both solid, and little or no paint on the axle shafts. Driver's side inner boot has no clamps, passenger side inner has one clamp on the inner side of the boot, none on the outer side. Outer boots are clamped on both ends.
After firing up the wood stove and staring at new and old, I just can't see myself putting these new replacements on the car.
I know from reading other posts on this topic that the preferred solution is to reboot the outers and swap outer joints side to side. I do have a set of Rein outer boots,, but I now know that one side is already a rebuilt. Is the reboot and flip outer joint still my best option? Can I tell whether or not the passenger side rebuilt axle is still an OEM axle?
The current axle boots have no issues with rips or tears, mileage on the VR6 donor car was ~140K. I suppose that I could put the donor axles in as is,, but would rather do this as few times as possible.
The drivers side CV on my '96 B4V let go,and it damaged the transmission housing.I usually go the NAPA route since they're easily accessible, in stock, and only $46 for the lifetime. I have had bad ones right out of the box and I have had good ones that lasted for many years. All have been rebuilt VW ones, complete with the VW numbers and stampings on them. I understand all they do is swap the parts and reboot them, but that's fine.
But, as I progress in years I am less and less inclined to risk having to do the job twice, so I will probably buy new next time.
Keep in mind that a bad CV joint, if ignored, will cause ancillary damage to connected components (wheel bearings & transmission seals immediately come to mind). And as Lug Nut mentioned, can leave you stranded when/if it grenades.
What exactly did it damage and can we get a picture?The drivers side CV on my '96 B4V let go,and it damaged the transmission housing.
well well well...I've bought several el cheapo ebay axles for various makes of cars...not had any problems that I can recall...
If autozone is close on price I just go that route...lifetime warranty ain't bad...and they are pretty good at keeping your records since the receipts tend to get lost...
There's another thread somewhere recently that talks about this.well well well...
been working on a new wheel bearing and hub pax side...bought a pair of each so decided to inspect the other "non-failed" driver side...
found a torn outter CV boot on the driver side...so decided to replace both CV axles...bought a pair at Autozone for like $40ish each, brought the cores back and they found my old AZ CV axles on file...so total refund/free swap out for both sides...
looks like I only got 60K from the axles from my records...well only one CV boot had failed and the joint was still tight...
now to figure out the cv bolt torque...My Haynes refers to 2 different type inner mounts and different torque values and they are quite different???
