compu_85
Gadget Guy
It also helps if you tell it the correct name from your phonebook
I'm not amused either. And I have read the manual several times.I was NOT amused.
Wet dog after a bath shaking off is used for rain sensor testing? I see the connection now.I just uploaded a demonstration of the rain-sensing auto-close feature for the windows and sunroof. Note: It's a lot more sensitive if you use a spray bottle rather than pouring water over the sensor.
http://www.youtube.com/watch?v=wGeXcubRNaE
Route 2 was reset when I last filled up, at the same time. As was regular trip odometer with the push button on the cluster.How many miles on MFA2? Just gotta check because it can be reset independently of the trip odometer.
Yeah we were out cruising around. MFA2 is showing ~38 mpg for the tank. Almost time for its first fill-up!
Very good! That puts you on track for a 900 mile tank.
I use that huuuuuge trunk and rear seats for all my camping gear, since I can't afford to fuel a motor home. Sometimes,, this trunk doesn't feel that deep, top to bottom in the height dept, and sometimes the hinges do get in the way when I have bulky stuff in there.Niner, why aren't you using that huge trunk you've got there for the bike???
$143 or there abouts, shipped. Some place in San Diego, there's a thread on it in here somewhere if you use the search feature.How much did the hitch for the Passat set you back?
I put the pump on automatic... drop a deuce.... put the pump on again, wash the front and rear windows, put the pump on again, and that pretty much burps all the foam out for a full tank to the brim. And if the Ahole that's in a hurry behind me doesn't like it, because he's late for work, he should have gotten there before me, as it's common knowledge that the early bird gets the worm, er fuel. Better yet, either leave early, or fill up on your drive home from work.Hey Niner, those numbers look very much like what I am getting these days, one thing I noticed is you have 465 miles and have not reached the 1/2 tank mark(looks like you will get 500ish), I can't quit get that much mileage on a 1/2 tank as I just can't get 18.5 gallons in there. I can get to around 430-440 at 1/2 tank(averaging 50-51mpg's) so I'm guessing you have approx 1.5 gallons more than I can get.
Are you driving in S or D mode? Freewheeling only works in D mode.I forgot to mention that our Passat won't freewheel... Need to do some investigating with VCDS to see if there's an adaptation to turn it on.
The trans "neutrals" itself when no input is detected on either pedal. Nothing new, lots of American cars do this, and VAG had an ill-fated autobox some decades ago called the "E-mode" that did it as well. It is a feature that is intended to reduce fuel consumption. Some find it quite annoying.Pardon me, but what exactly is free wheeling?
