PAJettaTDI
- Joined
- Sep 1, 2005
- TDI
- 2015 Passat TDI SE 6 Spd
2005.5 Jetta Change Rear Brake Pads - piston and brake cable?
Had my car into the dealer for inspection. My rear brake pads need replaced. I bought factory brake pads. The dealer informed me that the rear piston screws in.
I stopped by Advance on the way home and they sold me a small square tool with differently positioned fingers that are supposed to be compatible with many different makes of vehicles rear brake pistons.
I jacked the car, removed the two screws holding the caliper and removed the old pads and clips. I held the caliper in one hand and tried my tool to begin the job of turning in the piston, but it didn't fit. I had to file one set of the fingers into a V shape so that it would fit into each slot on the piston. I began turing. It took quite a bit of strength even with the tool and my ratchet. However, after about 20 minutes of turning, slipping, swearing and busting my knuckles, I realized that the piston is not any closer inward than when I started.
I guess the short of it is, what the heck do you need to do and is there any inexpensive tools that I can buy/borrow to accomplish this without having to take this back to the dealer or spend hundreds on special VW factory tools? It seems like this should be simple.
