zuks90idi said:Installed a new bumper and headlights.
What exactly will take it out? I've got the original clutch in my car and I've had a flutter in first gear for almost a year. It has had me worrying for quite some time.Growler said:so all of you with SMFs, if you start feeling vibrations when taking off in 1st gear.. you MIGHT want to start saving your pennies. you have time, but it can and will take out your engine eventually.
It's getting painted for sure.tothemax said:Looks pretty sharp with the Harlequin look.. Are you going to keep it that way or paint it black?
Are you gonna fill up the center hole below with an FMIC? Now you got lotsa room for one...
740GLE said:Put in a slightly used H&R 24mm rear sway bar in my sedan. Took an hour, in and out. I am very happy with the handling in the corners and on the highway. Well worth the cash and would highly recommend every Mk5 who wants a better "feeling" car to invest in either at least a GTI bar or an upgraded bar. The rest of the suspention is stock.
That would have been handy when I needed it done. I ended up paying a guy to put it on. $40 wasn't too bad though. Except for the part. $$$$shagin'wagen said:Anyone got a How To on changing the A/C clutch?
http://www.wikitdi.com/wiki/index.php?title=Rear_Brake_Pad_&_Rotor_replacementscotsditch said:Hey does anyone know where I can find a "how to" thread on replacing the driver side rear brake caliper?
Did you run the wires down the passenger pillar OE style, or did you do something else? I'm gonna do this in the next couple of weeks, and was just wondering how you did it!delvi__acevedo said:3 days ago retrofited a black auto dimming rear view mirror from a R32, I didn't care about the rain sensor feature and didn't want to change windshield just to have that funtion so I retrofited my stock rearview mirror base to the R32 mirror and wired it up and it works perfect. I'm happy
blizzard60 said:Did you run the wires down the passenger pillar OE style, or did you do something else? I'm gonna do this in the next couple of weeks, and was just wondering how you did it!
Cheers,
-Chris
actually I did a quick and dirty thing, I already had fused power up there for the V1 radar detector so I tap to that, the ground wire got hook up by the W8 console and on the reverse wire the mirror is really looking for ground and it gets this from the reverse wire at all times except when the reverse is engaged.blizzard60 said:Did you run the wires down the passenger pillar OE style, or did you do something else? I'm gonna do this in the next couple of weeks, and was just wondering how you did it!
Cheers,
-Chris
NB_TDi said:Today I added an "Aux" input inside the glove box....
Finally can listen to my Android phone and laptop without having to use a FM transmitter. Phone calls sound great on it too!
Nothing more than a run of the mill switch. Not sure why audio quality would suffer since the wiring is only 24 AWG anyway.mech644 said:What kind of DPDT switch did you use? Type of contacts? Just curious if Audio quality suffers?
