badgervwman
Passat TDI Automatic Transmission Gushing Noise Shifting
Hello, I have a 2004 VW Passat with an automatic transmission (tiptronic) that has 187,000 miles on it. I'm hearing a gurgling noise coming from the transmission when I shift gears in reverse and into drive. I started hearing this sound after I had a water pump replaced a second time. I'd like to know if this is normal for them too drop in trans fluid and just need a top up.
What is the best thing to do should I refill it and top it off or drain everything and drop the pan and replace the filter? I've read on other forums that replacing the original fluid and with fresh fluid will cause more damage and slippage. It's been shifting fine until I noticed this gushing noise just recently.
I'm stuck in a spot if I should do the service myself or take it took a local shop. I parked it for now and been driving my Jetta.
Thank you for your help,
Brandon
Brandon
