DSG Rattle
morpwr
Carleton Place, Ontario
2006 Jetta DSG Highline Red w/tan
Just bought a new dualmass flywheel from a trusted vendor. It was the LUK model most vendors are selling for my 06 with DSG. When the car is cold it is good when idling in gear at a stop light. After driving for awhile, there is a definite rattling sound, a lot like the old one made before I changed it. Has anyone else experienced this? Is it just normal for a LUK one to be so noisy? Thank you.:confused:
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
The DSG / DMF rattle is usually more present at idle on a COLD engine.
Is all the mounting hardware tight? Just asking to be sure.
Tony
narongc73
VA/OH
2006 Jetta TDI
If it still does it after the replacement, it's probably not the flywheel. It'll be something else. Post a vid?
SVTWEB
Beyond Comprehension
2010 Jetta TDI Cup-Edition EVO 4-Motion
+1 on Windjammer.... If you fixed the back half of the engine (DMF) the rattle is coming from the alternator pulley.....
