D_Bat
Just a few days ago it had trouble starting. I started it up one morning just fine then drove it to the store. Came out from the store and it took about 3-5 seconds of cranking till it turned over. Scared me and I posted on here and nobody replied.
It ran fine once started.
I hadn't tried to start it up till yesterday and the thing won't turn over at all now. It cranks and puffs out a decent amount of smoke out the back but no go. So it's getting fuel since there's smoke, the timing belt is totally fine and taught, it's been in the 70's here in Florida so it should just start up no problem at all.
Anything you guys think I should check out to try and find the source of the problem?
Also, belt, headgasket, ARP Headstuds, injector pump, glow plugs and harness were all changed/replaced with in the last 10k miles. Totally stock engine, no mods at all. EGR valve is clean and works fine.
