blujett2.0
What do the Valeo 1.9 TDI clutches cost? What is their power rating?
Did you go with a 240mm or 228mm setup?I have about 800km on my new setup and the clutch still is incredibly jerky trying to release. My old Valeo was very smooth engagement. Is it just nature of the setup or break-in??? I feel like a newb leaving stoplights! :S The new setup also chatters out of gear in idle now. It doesn't bother me but my old setup was silent. Growing pains I guess...
It's a 240mm. (Clutchmasters FX-25, 32lb flywheel) I'll give that a try Windex thanks! I've been trying to take it easy through break-in so I haven't really laid down the power yet. I'll try a higher rpm engagement and see if that helps.Did you go with a 240mm or 228mm setup?
I found with my darkside sourced Sachs SRE 240mm organic disc and factory DMF, that there was a fair amount of chatter on take-up initially but that you could mitigate by keeping revs higher. Now that I am 40k km on the setup, it's much better - only the higher pedal effort lets you know that it's a race clutch.
Never had a slip ever with the setup.
UPDATE: Thanks for the advice Whitbread. I ended up following his suggestion and the engagement is MUCH smoother. I now hit 1100miles on the new clutch and it's wearing in quite nice. VERY satisfied with the setup. Looking forward to posting back how it does with towing.I talked to blujett and gave him the suggestion of actually trying to keep the rpms at idle when letting the clutch out. I drove one of the fx350 setups with my 30lb flywheel for a few days and it's butter smooth letting the clutch out keeping the rpms at idle with 1100miles on it now. It's grabbier than a stock clutch, but zero shudder or vibration on engagement. I was pleasantly surprised just how smooth it was. Car had stock engine mounts and still had a bsm.
Anything to update? Looking to send my slipping Valeo off to south bend soon.I wanted to update this on my end since I know there are at least a few of you that are interested. I have installed the modified (u)s spec Valeo and I have had a chance to drive it several miles through the city. It is very similar to the original feel of the stock valeo, very smooth engagement and zero shutter. It is noticeably grabbier but not by a lot, very easy to drive. Once it is broken-in I will report back but so far I am very pleased.
You mean clutchmasters . Glad to hear it's serving you well! Did you try changing oil to redline lightweight shockproof to quiet the gear rattle at idle? I've had extremely good luck with it in any trans behind a tdi (including an NV3550 in a wrangler with an ahu) to nearly eliminate the gear rattle at idle.UPDATE: I'm at 5K miles on my Southbend clutch/Whitbread 35lb flywheel. I've been running it hard and no slipping at all. I've got used to the chatter on idle but I still don't think it's very much. I hooked up the camper and gave it a short run and it's solid! Thanks Whitbread!
How have the guys looking at refinishing the Valeo 1.8T clutches doing? Any updates?
WHOA! What am I smoking? YES I mean clutchmasters! I haven't upgraded the oil yet. I should get that done when the new cam goes in. Thanks!You mean clutchmasters . Glad to hear it's serving you well! Did you try changing oil to redline lightweight shockproof to quiet the gear rattle at idle? I've had extremely good luck with it in any trans behind a tdi (including an NV3550 in a wrangler with an ahu) to nearly eliminate the gear rattle at idle.
I think valeo uses a proprietary flywheel. Send the disk and PP to Southbend and have them reline it. My brother plans on doing the same, as well as another member on here did the same.I have a Valeo 835012 SMF kit for the 1.9 euro Passat tdi.
I got a stage 2 tune and it will slip a little in 4th and 5th if you are getting on it pretty good.
Will any other clutches fit my flywheel?
I do some fairly heavy towing so I am not sure the relining of my clutch will work or
not and I don't want any extra down time.
What is a Stage 2 Endurance lining? Fancy name for kevlar?I went with a Valeo SMF kit for the 1.8t passat and sent the whole kit to Southbend to have them reline it with the stage 2 endurance lining. I have a TDtune stage 2 tune and have about 5k miles on the setup, no slipping stock pedal feel and pretty smooth engagement. I think I gave $300 for the kit and $350 for southbend reline so $650 total. Several others on here have the same clutch and highly recommended it with many more miles than I have on mine.
From Southbend's website:What is a Stage 2 Endurance lining? Fancy name for kevlar?
