newlitemotorist
Ok guys, chances are if you own a b5 passat the thought of swapping in a manual has come to mind. With this swap being a fairly new concept, resources are hard to come by. For me, the most frustrating piece of the puzzle has been sourcing a good clutch that is affordable and that can handle a bit of torque beyond a stock replacement.
For the past few days I have been scouring the net in search of some viable options. I have come up with a list ranging from mild to wild with a few curve balls thrown into the mix. The criteria consisted of affordability, value and real world feedback. If anyone has any useful input on this topic please feel free to entertain us.
First I want to start off with a DMF setup for those who want the ultimate in flexibility and smooth operation. Luk has a full kit that is priced very well at $499 usd but keep in mind that this is a stock replacement kit. If you plan to push the envelope I would move on to one of the single mass flywheel conversion kits.
http://gripforce.com/luk-clutch-kit-dmf-flywheel-97-99-audi-a4-quattro-1-8t-vw-passat-1-8l-turbo/
228mm smf conversion Options:
First off, the tried and true valeo smf conversion kit. List price is 389.XX which is very reasonable if you don't plan to do much more than a tune.
http://www.ebay.com/itm/161027458656?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Next in line is the Eurospec smf conversion kit (part number 124 198 CFS 28 RED). List price ranges from 475 to 495. Based on the reviews this a step up from the valeo yet it still retains the stock pedal feel. How much better I do not know atm. If anyone knows the torque rating please fill us in but I have found quotes in the 300-350 ft-lb range.
http://www.bsatuning.com/FlywheelClutch-Kit-Audi-A4-VW-Passat-18T-5V-_p_998.html
Eurospecsport offers a step up from the above kit in the way of a hd clutch disc, all else remains the same as far as I can tell (part number 124 198 CFS RPD). List price ranges from 695 to 745. Again I have not been able to find a power rating.
http://www.bsatuning.com/FlywheelClutch-Kit-Audi-A4-VW-Passat-18T-5V-_p_999.html
South Bend offers a billet steel solid flywheel that weighs in at 17lbs which is the lightest many say you can go before chatter becomes an issue. The chatter comes from the springs on the disc, not the gears and if you get a floating center disc than this is not an issue. List price for this flywheel alone is 475 usd. Link below shows all of the solid flywheel options at ringer racing.
http://ringer-racing.com/product.sc?productId=61&categoryId=96
Southbend offers a full clutch kit using the above mentioned flywheel. They offer kits ranging from stock replacement to full race. Price starts at 900 usd and goes as high as 1175 usd. Torque ratings range from 280 to 425.
http://ringer-racing.com/product.sc?productId=109&categoryId=96
IF you are ok with running a lightweight flywheel (15lbs) I have sourced the following options. Believe it or not I have found some really rave reviews for the much cheaper of the two options listed below. The more expensive clutch masters kit is a no brain-er when it comes to quality though.
Gripforce offers a lineup of clutch kits that are the most affordable I have found. Now whether it is money well spent, ill leave that up for debate but I have found some really positive reviews from real people driving real cars. From my own research and based on a phone call made to them, they use sachs pressure plates and discs, the flywheel is made by them. Based on outsider reports, the hardware they send leaves a bit to be desired so you might want to source your own if you decide to give them a shot.
These are the two kits I have looked into. The kevlar kit has a torque rating of 362 ft-lb. List price is $379 usd.
http://gripforce.com/f1-seg-kevlar-clutch-kit-chromoly-flywheel-audi-a4-quattro-b5-vw-passat-1-8t/
The stage 3 has a torque rating of 335 ft-lb and is a 6 puck disc. List price is $347 usd.
http://gripforce.com/f1-stage-3-clu...1997-20-audi-a4-quattro-vw-passat-1-8l-turbo/
Clutch Masters offers some of the best clutch kits on the market but they are also some of the most expensive. Price ranges from 875 to 1200usd. Torque ratings range from 280 ft-lbs to 495 ft-lbs.
http://ringer-racing.com/product.sc?productId=260&categoryId=96
The next step up is to run a 240mm clutch kit. According to my research, moving up to a 240mm clutch allows you to run a stock replacement kit, retaining a completely stock pedal feel, all while enjoying much much higher torque handling capabilities. I know the 012 and 01E gear boxes will accept a 240mm clutch without any fuss but as for spacing i have no clue.
Clutchmasters is one of the few companies I have found through my limited efforts looking into the 240mm option. The fx100 which is the bottom line kit will hold a whopping 425 ft-lbs of torque. The reviews are rave, quiet operation, stock pedal feel, amazing grip. The fx450 holds 750 ft-lbs...
You can buy just the 240mm flywheel which weighs in at 19lbs for around $550 and then run your own disc and pp.
http://ringer-racing.com/product.sc?productId=99&categoryId=96
Or you can go all out and buy the kit, starting at $1134 usd. This is the route you would want to go if you plan to set records imo.
There you go, I have listed everything I could find but I am sure there are other options. I was shopping for something in the 5-600$ range that could hold some decent torque. It looks like the eurospec clutch might be the kit that best fits the bill here but that is for me.
I would like to make this a comprehensive thread that anyone can go to if they want to shop for a good clutch to complement their manual gearbox swap. Lets keep it real and informative...and lets show everyone their options!
Happy motoring...
Happy motoring...
