shawnsautorepair
Car came in on a trailer....customer stated that the car was running fine, stepped down to pass someone and lost power and died. Went out this morning, started car right up, ran fine, came around the block and into the shop and the car died in the doorway. Checked codes with Launch scanner and found the following:
01050 Glow Plug ckt
00553 MAF sensor
00519 intake manifold pressure sensor
key on..glow plug light lights, then goes out, have SES light. Full communication w/ scanner.
Crank car, car will start right up, run for a couple seconds, then stall....appears to have good fuel pressure at all injectors while cranking. Unplugged MAF, no change.
Just looking for a direction to go in with this....have checked Identifix and AllData to no avail.....I can see we're going to have to update to a different repair software for Volkswagen, as the AllData just isn't cutting it for Volkswagen repair......
Edit.......got car started...appears to be pulling air from somewhere, evident by air bubbles in the line going to the injector pump. Also, car smokes BADLY out the exhaust...more of a brownish/grey than black colored, but an EXTREME amount of smoke...you'd think I was starting a detroit diesel rather than a Volkswagen
01050 Glow Plug ckt
00553 MAF sensor
