I've spent a long time watching these values. I could share some actual data, but my car is modified quite a bit, so comparison would be unequal.
Specified is what the ECU expects to see for the given operating parameters. If the actual value varies from the specified value too much, then the ECU recognizes that as a problem and attempts to correct it or throws a code, depending on which monitor you're looking at. Just about every sensor has a specified value (derived from a programmed MAP in the ECU) and an actual value, which is what the sensor is telling the ECU is actually happening.
My group 11 specified value maxes out at 1836. If you apply WOT from idle, this value will increase from around 1200 at 1000 RPMS to a full 1836 (or so) at 1600 RPMS. The maximum spec value varies for elevation and intake air temperature.
Most cars' actual values exceed the specified value when boost is first applied. The ECU then reduces boost to match the specified value. 2245 peak is not an unusual value, but maybe a bit higher than I'd suspect for a stock TDI. Are you chipped? Your sustained boost at WOT should wander closely around the spec value of 1800-1900.
As far as being safe with this boost at 4300 feet - well, I'm on my second turbo. I lug my car, and I think the car should handle the lugging. If I have to worry about the load at low RPMs, I don't enjoy my car as much. So I'm an advocate for turning down the turbo boost at low RPMs via the VNT-1 adjustment. But that's a personal opinion. And I still lug my car just like I ever did - almost as bad as my wife does.
