Old January 11th, 2018, 07:15   #1
Exenos
TDI(s): 02 Golf
Default Manual glow plugs or ECU controlled?
I'm finishing up the last few bits of wiring on my truck and I'm trying to decide what to do with the glow plugs. Should I run them manually or let the ecu control them? I tend to lean towards manual control of stuff so I guess really what I'm asking is are there any real reasons to have the ecu control them or is that just a convenience?
Exenos is offline   Reply With Quote
Old January 11th, 2018, 07:24   #2
PickleRick
PickleRick's Avatar
I second this question and can the ecu be made to not throw a code with manual glow plugs.
Weddings are basically funerals with cake
PickleRick is offline   Reply With Quote
Old January 11th, 2018, 07:25   #3
compu_85
Gadget Guy
compu_85's Avatar
Why not have the ECU control them? Then you get afterglow and correctly timed preglow. It's just a few wires, hardly any more than doing a manual setup.
-J
Present:
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 23,000 miles.
2012 Passat SE TDI DSG. 112,000 miles. Factory Alarm, LED tails, Memory Seat, HIDs 38/48 MPG. Buy it from us!
2004 Touareg V10 TDI. 165,000 miles.
99.5 Jetta "GLX" TDI. 310,000 miles. Half way there!!! Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old January 11th, 2018, 07:41   #4
PickleRick
PickleRick's Avatar
I dont know about him but on my bhw swap simplicity. I dont use the boat unless the water is warm enough to swim in. That means it's May and lows in The 60s.
Old January 11th, 2018, 07:44   #5
compu_85
Gadget Guy
compu_85's Avatar
I'd still want the glow plugs to run every time (which they do even when warm, for the after-run period)... if they never cycle they can get carbon buildup, and then get stuck in the head.
-J
Old January 11th, 2018, 08:24   #6
PickleRick
PickleRick's Avatar
Good point...
Old January 11th, 2018, 12:37   #7
vtpsd
Fuel Economy: 45mpg avg
let the ECU do it! Its a great feature of the TDI. All the work to swap a TDI into something only to disable one of its great features? Makes no sense to me.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old January 11th, 2018, 13:23   #8
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Not the same, but I had 2 cylinder Volvo in my sailboat and it was a pig to start without glow plugs.
I would in this case go automatic, no guessing when and how long to cycle glow plugs.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Old January 13th, 2018, 08:22   #9
QuickTD
Simplicity on a BHW would be accomplished by leaving the glow plug system as-is. The glow relay is integrated into the engine wiring harness and does not require any outside wiring other than a 50 amp fused battery feed.
Also, BHW glow plugs (depending on version) are either 5volt or 7volt and require a PWM controller to operate from a 12volt source. The factory glow plug relay is not actually a relay, it is a PWM power amplifier. The ECU drives it with a PWM signal. The glow "relay" also reports individual glow plug current back to the ECU to sense glow plug failure.
QuickTD is offline   Reply With Quote
Old January 13th, 2018, 11:34   #10
Steve Addy
TDI(s): 97 Mk3
If you have the ECU installed I see no reason not to let it perform this function, as others have said it provides the post-start glow cycle function too so it has a lot of benefit.
In this case it relieves you of having to push and hold a button for some unknown amount of time too.
Steve
You didn't poison the coffee, did you? Not anymore than I usually do.
Old January 13th, 2018, 20:50   #11
Exenos
TDI(s): 02 Golf
Alright, fine. I guess I'll just let the ecu do its thing. And here I was hoping I could add another switch to my dash...
Old January 14th, 2018, 19:35   #12
PickleRick
PickleRick's Avatar
If you do decide on manual glow plugs dont use a switch unless it opens back up automatically. If you forget to turn it off, you can drain your battery and kill your glow plugs at The same time.
I usually used an old push button style. Count to five and start.
Old January 15th, 2018, 12:52   #13
Hasenwerk
Hasenwerk's Avatar
You CAN also have a manual switch as well. One of the wires to the glow plug relay goes low when the ECU wants to turn it on. You can connect to that wire, ground it with your switch and the glow plug relay will turn on. Now, if the ECU then throws an error or not is another question.
I can't really see a need for this though as the ECU does a good job at regulating the glow plugs. You can via software change how long and what temperature the glow plugs active too.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
BEW glow plugs, which ECU flash? luxuryrules VW MKIV-A4 TDIs (VE and PD) 17 February 20th, 2016 15:27
Exactly what temp before ECU commands glow plugs? firehawk618 VW MKIV-A4 TDIs (VE and PD) 22 November 12th, 2012 15:34
Need to find Trusted ECU falsh over for PD Glow plugs tdiDerry Eastern USA 2 June 8th, 2010 17:57
Glow plugs, ECU, 109 relay, no power, hard start PROBLEMS Please help me madhatcher TDI 101 6 May 15th, 2009 22:46
Coolant leaking around manual transmission glow plugs theaussiepea VW MKIV-A4 TDIs (VE and PD) 8 April 21st, 2006 08:37
Page generated in 0.17283 seconds with 12 queries
[Output: 116.45 Kb. compressed to 97.75 Kb. by saving 18.70 Kb. (16.06%)]
