dieseldorf
OK, I'll check this evening. I have a MityVac so we can get a measurement.
Do you recall what the readings were you measured?
Do you mean this?Sure enough, I had the H part on our 2003 wagon.
I would spend the hour and do it. It's not worth the agravation IMO.Sender Unit # 1J0 919 183F, this is what is in my car, not the C or D or H (03 Jetta StnWgn) Anyone else have this unit? It has not been mentioned in any other messages and I am wondering if this unit needs to be drilled out.
Any help much appreciated.
If you don't see temps below 15F, I wouldn't bother. If you need to mix your fuel more than once or twice over the winter, then save yourself a headache and do the mod... it's only an hours time.I live in NC and use the anti-gel stuff. But, if it got very cold I could blend some fuel. Does anyone know what blends are used in the North? I thought you just add kerosene to the fuel which is readily available at most gas stations here in NC. That would be easier than drilling out the valve.
i would take it apart(sorry) and see if there is a check valve.if there is drill it..Sender Unit # 1J0 919 183F, this is what is in my car, not the C or D or H (03 Jetta StnWgn) Anyone else have this unit? It has not been mentioned in any other messages and I am wondering if this unit needs to be drilled out.
