Green Waters
I had my struts and mounts replaced at 265k with monroe struts/mounts on 99 jetta tdi. I since have had it in to two other service shops for exhaust and a tire repair and both indicated that they thought the mounts/struts were bad due to excessive movement in the mounts. I had the front mounts replaced again under warranty at about 278k at the same repair shop I had them done at because of concern for excessive movement and now at 281k another shop has the same concern. How much up/down movement is acceptable with these mounts? I can't see them being bad as it took me 265k to have the first set replaced. Any thoughts? I don't want to keep hearing for the next 265k that I need these replaced everytime I take it in for work.
