Hi everyone
I would like to present my project.
Project Specs:
Chassis: '99 Audi A4 Quattro. 1,9 TDI AFN(ecu018X) with cleanA4/S4 Body
OEM Power: Serie -110Hp/mod - 207HP(VP Engine
OEM Transmssion Specs: 5 spd, 01A /diferecial - swap AudiV8 Torsen
Old Pics(2007-2016)
Engine VP specs:
- Turbo - GTB1756VK
- injectors - Firad 0,250
- diesel pomp - 107J factory
- camshaft - 1,9 SDI
- Intercooler - 180x550x65
- Brakes - 312/269 from A6 C5
- VFIZ with boost/egt
- clutch from 130PD AWX 228
That's ****...
________________________________________________________
New Engine is AVF 2004 from A4 B6 130hp swaped into A4 B5.(ECU from AJM with CAN BUS)
OEM Power: Serie -130Hp/mod - 322HP(PD Engine)
OEM Transmssion Specs: 6 spd, 01E(DQT) /diferecial - swap Audi80 diff-lock
New Pics(2016-2019)
Engine PD specs:
- turbo GTD2060VZ
- injectors PD - FIRAD HF100%(111mg)
- camshaft - 2,0SDI
- 130PD ported Head and bigger valves
- custom intake manifold from VW LT
- second external fuel pump
- Intercooler 280x450x100
- external oil cooler
- colorMFA with boost
- custom EGT gauge in interior lamp
- custom dual clutch from 3,0TDI
- swap 6gang gearbox from A6 C5 2,5TDI Quattro and Diff from Audi80
- adapted CAN BUS
- Brakes 345/330 from S4B6/A6C6
Project Specs:
Old Pics(2007-2016)
Engine VP specs:
- Turbo - GTB1756VK
That's ****...
New Pics(2016-2019)
Engine PD specs:
- turbo GTD2060VZ
- camshaft - 2,0SDI
- adapted CAN BUS
