cruisinflatout
Picked up an 04 Jetta TDI a month ago. 368K on the clock (TB & WP done 30K ago).
When I put on my AC I hear a chatter under the hood. AC does push out cold air.
When I took a look under the hood with it running and AC turned on u can see the accessory belt tensioner slapping back and forth making the chatter sound.
Is this a tensioner problem? Without AC on it seems calm and as it should be. Or is this an AC clutch problem or other AC problem?
Thanks in advance for your advice.
Kevin
Kevin
