Hello all,
Mew member here looking for help. Recently purchased a 2007 1.9tdi golf sport with the BXE engine.
I bought the car knowing it had a misfire.
So I have a launch scanner not vcds sadly but it gives me most of the things I need.
Symptoms.
Cars starts fine and no excessive smoke from exhaust and engine sounds normal (no clattering etc).
At idle the engine shakes and it's obvious its misfiring, it misfires almost constantly but occasionally it smooths itself out momentarily.
Scanned ECU and have code p0301 misfire cylinder 1 detected.
If I look at injection quantity deviation I have the following readings on a warm engine at idle
Cylinder 1 = 2.47 mg/H
Cylinder 2 = -1.32 mg/H
Cylinder 3 = -0.96 mg/H
Cylinder 4 = -0.45 mg/H
So I know j have an issue on cylinder 1 as the ECU (I assume) is trying to compensate. Does this look like a faulty injector on cylinder 1 or what would you suggest.
I'm competent with tools so fire away!
Matt
Symptoms.
Matt
