Old July 14th, 2017, 10:00   #1
ChatNoirTDI
Default Check Engine Light - P2002
Greetings,
My Check Engine light came on (solid yellow). Took the car in to a nearby Pep Boys, and they came up with a P2002 code. Took the car in to the dealer the next morning, and they diagnosed the cause of the fault as a leak in the boost hose (going to the intercoolor) and a leak in the pressure hose (to the equivalent of the throttle body). Cost to repair about $750.
Does this make sense?
I have a 2013 Jetta TDI, about 31,000 miles.
Your kind advise is appreciated.
ChatNoirTDI is offline   Reply With Quote
Old July 14th, 2017, 10:37   #2
JETaah
PepBoys may not be able to read all the codes but...
http://wiki.ross-tech.com/wiki/index...4/P2002/008194
Those exhaust pressure sensors are a known sore spot on these cars.
Get your car away from the dealer.
Check the trusted mechanics list at the top of this page in the sticky threads for someone in your area and see what codes they come up with.
If it requires that an intake hose needs to be replaced (doubt it but, just in case), then you can usually get one at an on-line VW dealer for much less than walking up to the counter.
At that mileage, if it is an emissions related problem, (DPF or exhaust pressure sensor), it may still be under VW warranty.
I could be wrong.
Old July 14th, 2017, 13:28   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Try a different dealer/shop.
BobnOH is online now   Reply With Quote
Old July 15th, 2017, 07:57   #4
eddieleephd
Fuel Economy: 38mix / 47@70-75
The Dealer says an exhaust issue if related to the intake? Think about that for a moment.
If the code flashes for the exhaust the intake is not the culprit.
The engine is between them and the ECM knows better than the dealer.
Definitely get it to someone listed in the trusted mechanics list.
If I took it back to the dealer, I would ask them to guarantee their work and that if the parts replaced do not fix the issue they eat the cost and labor!
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old July 15th, 2017, 08:39   #5
tadawson
They would probably just drop in an entire engine then so they could not be wrong . . . and bill accordingly, sadly . . .
tadawson is offline   Reply With Quote
Old July 15th, 2017, 09:26   #6
eddieleephd
And if it's the DPF, not the engine, they eat the cost of a new engine too.
Get things in writing!
The diagnosis needs to be for the DPF, not the engine or intake.
Don't let them mess with things the codes are not thrown for!
Ask to see the full scan print out too so you can understand more about it.
Auto store scanners don't see everything!
Old July 15th, 2017, 17:52   #7
ChatNoirTDI
Thanks All for your kind replies.
Ended up authorizing the dealer to go ahead with the repair...recommended private shop couldn't take my car in until next Wednesday, was already three days into a rental car, plus labor costs at the dealer for diagnostics.
Told P2002 fault (particulate trap bank 1 efficiency below threshold) cleared after leaking hose replaced. Received defective hose with obvious leak from mechanic.
Drove car on freeway, today, for about 30 minutes, higher speeds...Check engine light remained off; performance okay.
Have job Sunday requiring about 100 miles highway driving. Fingers crossed...
If problem not resolved, when should Check Engine light reappear? What else should I look for?
Best regards and, again, my thanks.
Old August 1st, 2017, 04:34   #8
ChatNoirTDI
Well...in just under two weeks of driving, the engine light came on again...local Autozone identified same P2002 code. Returned to dealer. Told DPF needs to be replaced (under warranty). Concerned at this premature DPF failure. Any other issues I should be concerned about?
Old August 1st, 2017, 14:33   #9
Lightflyer1
Lightflyer1's Avatar
Either the dpf was cracked (common) or you aren't letting it regen properly when it's needed.
Old August 1st, 2017, 21:36   #10
UhOh
UhOh's Avatar
Cracked DPF? Is this unique to VAG? For the automotive industry? Or is this a general statement on DPFs?
Reason I'm asking is because my tractor has a DPF (no other diesels I own do). I'd never read of such a problem until now. In tractor miles, a DPF is supposed to be warrantied for 3,000 hrs, at which time they're supposedly able to be cleaned to then go for many more hours: I don't expect to ever see these kinds of hours, which is why I didn't worry about getting a tractor with a DPF.
Regarding the OP's issue, I suspect that this is probably SOP for VAG. Replace some easier/cheaper things first hoping the problem is resolved, and only change the DPF as a last resort. May need to first prove that other things aren't responsible before attempting the more expensive repair (when on VAG's dime).
UhOh is offline   Reply With Quote
Old October 1st, 2018, 16:48   #11
DieselMann99
MY CEL just came on and it's a P2002 Code: "Particulate Trap Efficiency Below Threshold"
I plan on doing the buyback very soon, good chance within 30-60 days. Can I do any major harm driving the car for 30-60 days, which would probably be no more than about 1,500 miles?
Also, is there anything I can do to make the problem go away? I've been doing just a little reading up on it. If I drive the car a little hard at higher RPMs for 20 minutes, might that make the problem go away?
DieselMann99 is offline   Reply With Quote
Old October 2nd, 2018, 07:26   #12
flee
flee's Avatar
Fuel Economy: 40-ish
I've been getting that CEL on the 2012 on and off for almost a year.
Don't worry too much. It may come and go but it doesn't affect driving noticeably.
I'm doing the buyback in 10 days also.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old October 2nd, 2018, 07:38   #13
vincej
The only CEL light I remember on my 2013 was P048C exhaust flap malfunction which had a SB out on it and the exhaust flap was replaced on warranty.
vincej is offline   Reply With Quote
Old June 12th, 2019, 13:29   #14
eastham67
2003 Jetta tdi no lights who can fix my smog in Torrance Ca 90505 comprehensive component
ent
eastham67 is offline   Reply With Quote
Old June 12th, 2019, 13:42   #15
Lightflyer1
ent
You should start your own thread and be a little more clear about what you need and what is happening.
Check Engine Light - P2002 ChatNoirTDI TDI 101 0 July 14th, 2017 09:58
2009 tdi wont pass e check. No check engine light on 04trd TDI (Diesel) Emissions 8 November 2nd, 2015 18:52
Check engine light-glow plug light & limp mode Slothbar VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 November 30th, 2013 10:30
my first check engine light, glow plugs, what to check... noxneon VW MKIV-A4 TDIs (VE and PD) 3 July 15th, 2013 19:00
HELP! Check engine light is not visible...failing CA smog check. redscare TDI 101 3 April 4th, 2011 21:20
Page generated in 0.18213 seconds with 12 queries
[Output: 126.41 Kb. compressed to 105.05 Kb. by saving 21.36 Kb. (16.90%)]
