This oil has boron in it which I have never seen in a VW spec. oil( not that that is a problem as it reduces ash). That also helps keep the TBN up.
Low ash oils like the 507 oil have reduced Zddp(zinc/phosphorous), about 650 to 750 ppm phosphorous to allow for a reduced amount of calcium detergent, usually well under 2000 ppm especially if it is a boron calcium combination.
Anyways the 108 iron is unusual for this engine unless it is low mileage and should be almost broken in at 50,000 miles. So the question is. Is this a low mileage engine being broken in?
The fact that you are even considering MolyS2 is worrisome. This is a lot of sulphur and would not be good.
I assume you have drained and replaced filter and oil. I would drop a line to Terry Dyson and ask him to provide a plan to analyse your oil and determine what is causing the possible excessive oil, (edit to), iron wear.
www.dysonanalysis.com
