I need to pull the thing to change out some shims I had put in there for rear toe.
The four bolts that hold it in the two rears are easy to loosen, but the front two are impossible to get any normal wrench on without getting the abs wheel and hub etc out of the way.
How is this pulled? Is there a nut under the end cab furtherest outboard at center of hub? I think I'll need to use a slide hammer to yank the thing off to get to these bolts? Not apparent how the thing is assembled, and naturally harder to work on that it probably should be.
I found a thin metal ring floating in there too. Not sure if I knocked it loose or it was already...guessing was loose already.
