DothanTDI
No Low Beams, I\'m at work and can\'t go home
I tried the DRL disable on my 2003 Golf from http://www.bugmod.com/drl_tfl.htm. The daytime running lamps wouldn't come on (as expected) but the low beams headlights would not work either. So I took the tape back of the TFL pin. Now DRL works but I have no headlamps on low beam. I am thinking about disconnecting the battery to see if all will return to normal. I am stuck at work. Anyone have any experience with this? My only other choice is to drive home with high beams. HELP!
