I have a problem i'm trying to figure out since I have owned this vehicle for about a year now, either its normal for these cars or not, and would like some feedback please!
I have a 02 ALH with .216 nozzles, malone stage 3, clutch/flywheel upgrade, 2.5" turbo back exhaust with a "high flow" cat and straight through muffler, stage 3 malone tune. It was stock when I got it, so all these upgrades are my own. I still have my egr.
I would also like to point out that I have replaced all my vaccum lines, the n75, replaced my turbo with another gt1749v cause the one that was in the car was pooched. actuator came with it, I only recently readjusted it, I lengthened it to hopefully aid this issue I have but its the same regardless and i lost 3 pounds on the high end, no matter. I cleaned my maf and my map sensors and looked via VagCom and they responded fine. I have cleaned everything, and looked everywhere. Now the ONLY thing I havnt done is reseal the inside of my vacuum pump that used to seep oil through that seal that the nipple sits inside, I rtv'd it and it responded better for a bit, but went back to the same old ish.
At the moment of acceleration at any speed or gear, I get this initial lag, for a good second or 2. Feels like the car is bottling up power and something "aka waste-gate im guessing" Opens and the car really gets going. I have a boost gauge and it shows me a good spike no matter if i'm lightly throttling it. From what I understand this is when the turbo builds boost before the vanes open up. But during this "boost build" Feels like I'm receiving none.
So, lightly accelerating, i use to get 10 pounds then fly back down to the requested 3-5, since actuator adjustment it now goes to 5 pounds and settles at 1-2. It is less noticeable under very light driving, but as soon as you need some nuts to get going, especially uphill (it takes a good 3-4 seconds to settle and take off then).
Under heavy throttle, I spike to a good 20 pounds, then dip down to 15 then hold at 18. but its a very annoying torque spike that I cant just gentle get into, its very sudden, now before people say that I'm running an aggressive tune, Sure, But I should still be able to ease into it without driving like a turtle. My 1.8t never did this, Sure there was a little bit of lag but not on the scale of this.
This is very annoying to me because even with moderate city driving, the after effect of it is torque spike and then you have to let off, then you have to get on it a bit again only to come back to square one of this boost building situation. Its even more annoying when you have to go through the 1-3 gears and the guy behind you is accelerating only to have put on his brakes cause im now decelerating from this good 2-3 second lag, and then he gets a puff of black smoke cause now I feel obliged to push the car a little more to get it going.
Under WOT and in between gear shifts, this happens as well BUT, Less lag in between. depends on how high you get into the rpm's before shift.
This also can happen if you are just normal driving, then push it, then normal driving again. It'll spike, I hear its normal, but is it actually like, THAT normal?
EDIT: During these boost spikes is the lag i'm receiving, after it settles it takes off.
Please Help. Any questions ask ahead.
Thanks!
Thanks!
