LukeyBabes
Heya guys
I’m completely new to diesels and I know sort of how they operate. I’m sure I can learn a lot from this forum though.
I recently bought and have just started driving a 2005 audi allroad with the 2.5tdi BAU engine.
It seems to have an intermittent cold starting issue. Sometimes it will crank and crank for what seems like ages and eventually fire. And other times it takes a little longer than I'm used to in a petrol car. Might be normal, I don't know.
I only have one fault code which is
00560 - Exhaust gas recirculation system
08-10 - Control limit Surpassed - Intermittent
Could the EGR valve being stuck open with the build up of carbon cause a cold start issue? I.e. sucking air in through the exhaust instead of through the inlet/MAF. Could I unplug the MAF and try to start it to test this theory? I know on my old 1.8t petrol passat when the MAF went bad. I just unplugged it. Ran great until I got a new one.
It starts great when its warm and doesn't seem down on power but I've only driven it like this I guess.
Any help would be greatly appreciated.
