Old February 9th, 2017, 05:45   #31
jdulle
So if you are driving a lot at night, it might make sense. It would be small, the difference. But every little thing adds up. Just like with the insight, they did so many things to improve aero and lighten the car. The bottom third of the engine is magnesium. The valve cover gasket is plastic. The hood is carbon fiber. The rear drums are aluminum. I just replaced the license plate lights, and IIRC some running lights on the front of the car with LED. Partly I hate when you go to the auto parts store and they charge 4 or 5$ for 2 tiny bulbs, and the second one sits in the glove box and eventually gets broken. The LEDs will last the life of the car. I would get LRR tires when the ones on there wear out, and inflate to 40psi. They will save more fuel than the LEDs, but it will also be minor. Biggest savings are from driving slower, and the grill block. I have not done the grill block on my tdi because I don't drive it in the winter, but my insight has a full block and the civic has 3/4 blocked off in the winter.
jdulle is offline   Reply With Quote
Old February 9th, 2017, 17:29   #32
eddieleephd
Fuel Economy: 45-51.9
Originally Posted by turbovan+tdi View Post
Why is it unfortunate? You'd be the first one that cut their bill by 40% changing to LED's. I've done it, my friends have done it and the bill didn't change one bit, or if it did, not enough to notice. 40% is cutting your bill in half, the only way I can see it being done is if you left every light on in the house 24 hours a day.
Either way, glad it worked out for you.
Do you have kids? Yes the lights stay on 90% of the time no matter what you do!
I am a sustainability professional and it is not BS.
If you change from CFL's the difference will not be this dramatic.
However, CFL's use 70% less energy than incandescent's and LED's use 85% less than incandescent's.
The greatest difference in the long run between LED and CFL's are the lifetime of the bulb.
Another great thing about LED bulbs is spectrum availability. Use daylight spectrum and you will see true color!
My bulbs by the way are 4 years old or so.
I recommend getting them at the hardware store when the power company is doing their mandatory subsidization. I got my bulbs for around $3 each Regular $7-$9.
I am all for going to DC lighting throughout the house.
Both CFL's and LED's can operate on DC more efficiently than AC.
This would create an even greater reduction in energy consumption due to lack of conversion, or more correctly stated rectification.
So far as Automotive bulbs goes the design of the vehicle limits greatly the benefit to using LED.
For our VW's, LED headlights are not compatible with the bulb housing.
LED bulbs are only really viable in sockets inside the vehicle and exterior for markers, backup lights (which correct ones would be great), and the license plate lamp.
Power consumption will not be that greatly reduced and the main benefits would be greater illumination and a longer lifetime if you get good quality bulbs.
Just as with any other part on our cars, CHEAP is WORTHLESS!
Use Quality LED bulbs in the right spot and never replace them.
You can use LED with resistors built in if they are quality and they will not negatively affect the experience of driving, however, longer life is the sole benefit!
You will never save enough energy with automotive bulbs to pay for them, however, you may go through few enough bulbs to pay for them.
2003 Jetta Wagon Alh w/5spd swap, Al~Panzer pl ""
eddieleephd is offline   Reply With Quote
Old February 9th, 2017, 17:49   #33
U4ick
Originally Posted by TDIMeister View Post
I have to call fake news on this one.
Damn......Do you just like to argue? Ha Ha Ha
U4ick is offline   Reply With Quote
Old February 9th, 2017, 18:40   #34
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
Cheaper at costco, got 100s for 1.79, 60s for 1.65
1999 Golf TDi Variant Suspension TT bushings
2003 Jetta GLS TDi
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old February 9th, 2017, 20:39   #35
turbovan+tdi
turbovan+tdi's Avatar
Lol.
1984 6.2 Diesel Get A Way van, remote turbo setup designed/installed by me, burning anything that burns.
2003 GSW, 2.0L ALH, Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2004 GSW TDI, blue, 5 speed-Daily driver-malone stage 2, no kitty, aeroturbine muffler.
2003 JSW 1.8T future TDI, silver. 2006 JSW, TDI 5 speed, blue.
turbovan+tdi is online now   Reply With Quote
Old February 10th, 2017, 06:29   #36
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Don't conflate color temperature and color rendering index. To see true color, you need high CRI. Color temperature is just the tone of the light (warm/cool). Most of the "daylight" LEDs and CFLs you find in places like Home Depot and Lowe's are only ~80 CRI.
There are some daylight spectrum lamps that mimic actual daylight (about 5000K and 98 CRI), but they're pretty expensive and not available at your local hardware store.
You also don't want lights that are too blue/cool at night, as blue light slows natural melatonin production and screws up the body's circadian rhythm.
</offtopic>
Trusted TDI Mechanics Map || TDIClub Chat
Old February 16th, 2017, 14:11   #37
eddieleephd
</offtopic>
You are correct, but please don't put anything in the bathroom or bedroom that isn't daylight spectrum, if LED go dimmable too.
Wherever the woman does her makeup is best to use daylight spectrum.
Temperature of the bulbs isn't nearly as important as spectrum.
Have you ever looked at something indoors and thought it had an awesome color, like at the store, then got outside and saw it in the daylight only to think this looks horrible?
Spectrum of the bulb distorts the color. Yellow reflects back yellow well but your greens and other colors will look funky and the yellow will even be different outside.
Old February 16th, 2017, 22:55   #38
TomB
Fuel Economy: 34 mpg on first tank
LOL! Is this seriously a real post?
That usage is so minor... No real impact.
Yeah get rid of that alternator and run off battery. When do you charge the battery, it goes dead eventually?
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Fuel economy of Dieselgate TDIs removed from EPA's fuel economy website and datafiles Max Period Dieselgate - VW Group Emission Scandal 0 October 28th, 2016 22:24
LED tail lights and reverse lights 2011 TDI Upgrades (non TDI Engine related) 5 June 11th, 2016 06:44
2010-11 Projector Headlights, LED Tail lights & HID fog lights for sale! DUDA Private TDI Items for Sale/Wanted 7 December 16th, 2011 05:35
replacing map lights, dome light and trunk lights with bright led's rock88 TDI 101 1 August 20th, 2010 15:32
Copyright - TDIClub Online LTD - 2014
1996 - 2015, All Rights Reserved
Page generated in 0.15618 seconds with 12 queries
[Output: 96.04 Kb. compressed to 83.71 Kb. by saving 12.33 Kb. (12.84%)]
