shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
I was wandering around a junkyard yesterday and came upon a VW with an AHU TDI engine. The pump was gone, but the injectors were still there, so I tried to remove them, but the hold down screws were stripped and wouldn't come out.
So today I went back armed with several ways to pry on the hold down while unscrewing the bolt. I figured maybe I could pry up enough to get the threads to bite -- but no luck. In the process, I discovered that the glow plugs are stripped as well. I think someone might have sabotaged them with an impact wrench.
So I'm debating whether to try a third time or not. I think maybe a hacksaw blade/holder might cut through the hold downs and let me snatch the injectors. Or maybe even a cordless angle grinder, but I think maybe the wheel would be too big. But I might have clearance to use the angle grinder to cut the heads off the hold down bolts.
Any other ideas or comments about the wisdom of trying again? The junkyard is about 90 minutes one way from my house, and the set of injectors will cost me $40 if I can get them out. Looks like I can get a set on eBay for about $140.
