2003 VW Jetta 1.9L TDI ALH Auto trans
Bought Jetta with a blown engine. Bought an engine from the junk yard that was running. It came out of an 00'-01' Beetle. Completely went through the engine and checked it all out. I used the injectors out of the original engine but the injection pump is out of the beetle engine. They are both 11mm pumps. I started the motor today for the first time and it starts fine, runs about 3-5 seconds then starts surging and bellowing black smoke. When you push the accelerator pedal nothing really happens. I started it several times and after the engine warmed up a bit it smoothed out and gradually quit smoking. I let the engine idle for about an hour and would occasionally mash the accelerator down to about 3500 rpms. It was a bit sluggish but would accelerate with no problem. I let the motor cool off and restarted the engine and now the same symptoms are occurring again.
Looking for input and advice. Thanks.
I have searched the forums and haven't found anything that's exactly like the symptoms I am having.
