Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2010
TDIFest 2010 Discussion about TDIFest 2010 on the Labour Day weekend (September 3-5th, 2010) .
Old March 29th, 2010, 11:23   #1
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
Default Suggested Tdi Mods to be Performed this Year
There does not appear to be any fun threads here, so how about a thread dealing with suggested Tdi Mods?. Here are a few ideas to bantor about:
1. Converting a 5 speed Manual Transmission (o2J) to an Automatic Transmission (o1m);
2. Adding a WVO system to a 2009 CR Loyalty Edition model;
3. Converting a metal skidplate to an OEM Plastic model;
4. A how to remove your aftermarket tune;
5. Adding that perfect factory seat to replace your Recaro add in;
6. Replacing OEM Hid lights for ecodes;
7. How to remove your .658/.681 gear for stock;
8. How to kill your HPFP;
9. How to replace a 17/22 with a vnt 15;
10. How to add a K&N Air Filter.
Just some suggestions ........ Thoughts?
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old March 29th, 2010, 15:19   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
I'd like to know how to replace the crappy synthetic oil in my TDI with super-outstanding conventional oil.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old March 29th, 2010, 15:21   #3
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
Installing Automatic Nozzles for increased injection pressure.
How to replace your G60/VR6 for a smooth Sachs DMF (I'm gonna be responsible for the disposal of the G60 flywheels)
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Torque_Delight is offline   Reply With Quote
Old March 29th, 2010, 16:01   #4
fnjimmy!
Chucklechump
fnjimmy!'s Avatar
TDI(s): TDIdiot
Convert your gear-driven Passat BSM to a nice, quiet chain-driven unit.
Add in-dash cupholders to your late Mk4.
Swap out your heavy large-roller timing belt setup for a lightweight 99.5 model using the mark-and-pray method.
Cheers,
Jim
fnjimmy! is offline   Reply With Quote
Old March 29th, 2010, 16:09   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Originally Posted by thebigarniedog
1. Converting a 5 speed Manual Transmission (02J) to an Automatic Transmission (01M)
Make that swapping out the 02A and swapping in the 01M, and I'll attend that session.
Svante Arrhenius 1896
Old March 29th, 2010, 16:21   #6
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Replace that communist-housing-block-grey Relay 109 with a svelte black model.
Ditch that unreliable rubberband of a timing belt for a much more reliable chain-drive system from a VR6.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old March 29th, 2010, 16:27   #7
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
to replace you're Recaro add in;
And let us not forget a grammar, spelling & posting etiquette seminar from TBAD.
Old March 29th, 2010, 16:55   #8
thebigarniedog
LOL, I'll have to fit that in with a talk on how to convert your tdi to a CNG vehicle.
Old March 29th, 2010, 17:56   #9
Torque_Delight
Modded
How to replace the coilpacks
Old March 29th, 2010, 17:58   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Spark plugs, cap and distributor too. And wires.
Old March 29th, 2010, 18:38   #11
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Replacing the outdated ALH GP system with one of two options: robust yet ineffective ceramic GPs or frangible but stout steel GPs.
Old March 30th, 2010, 07:49   #12
KROUT
persona non grata
I say throw out all the mods and get new ones. New mods are better than old mods full of hot air.
KROUT is offline   Reply With Quote
Old March 30th, 2010, 11:15   #13
FlashT
Here's a suggestion:
http://ecomodder.com/forum/showthrea...take-6217.html
Thinking of lowering? Read This first.
FlashT is offline   Reply With Quote
Old April 1st, 2010, 09:31   #14
Brokk
Brokk's Avatar
Fuel Economy: 46 - 51
I think this post was started a few days too early. Today would have been more appropriate no?
--Curt
Brokk is offline   Reply With Quote
Old April 1st, 2010, 09:41   #15
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Efficiency Mod: How to trade in your TDI for a Prius and get the best deal?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Page generated in 0.15796 seconds with 10 queries
[Output: 129.14 Kb. compressed to 106.67 Kb. by saving 22.47 Kb. (17.40%)]
