EnthymematisHabilis
I've just noticed, now that it's windows open type weather, (actually my wife pointed it out) that the front passenger window is acting weird.
When you roll it up from either the driver or passenger control switch it stops when it's about 4 inches from being closed and then it rolls down again. If I try to close it using the one-touch close on the drivers switch I cannot close it since it just rolls itself down again. In order to close it I have to hold the switch up so it gets past that 4" from being closed point and actually closes.
I'm not sure if there is something I can do or check in VAG-com to fix this but I'm beginning to suspect it might be related to the anti-pinch feature of the power windows messing up somehow.
Any suggestions would be great,
thanks all,
David
thanks all,
David
