Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old July 3rd, 2019, 18:49   #31
[486]
TDI(s): 02 golf ALH
Originally Posted by DudaEnergy View Post
The engine is just a simple supercharged 2 cycle so you'd think out of all engines that it'd do well. Nope.
well, they are very lightly stressed engines. Producing well under 50hp/liter I doubt the piston crowns would get hot enough to burn the coke off.
Pattern is staying steady on my car, drive gently and it cokes up in about 200 miles. Beat the piss outta it and it cleans right up (with some prodigious discharge of smoke, bet the chunks are not good for my turbines)
Old August 10th, 2019, 06:45   #32
[486]
TDI(s): 02 golf ALH
finally had trouble
was running a higher percentage of gasoline (maybe 30 percent) and driving in hotter weather than normal, hundred degrees or so, parked it for ten minutes or so and engine heat soaked into the IP
hot restarts are troublesome, as the fuel in the injection pump will boil once there isn't case pressure holding it in liquid state.
Though, I'm running some stupid big injection hardware with no fuel cooler so that may feed into it.
Little bit of water on the IP got it going again
Old August 10th, 2019, 10:43   #33
turbobrick240
turbobrick240's Avatar
My Kubotas injection pump gets very unhappy with just a splash of gas in the fuel. Same sort of thing, almost seems like vapor lock.
turbobrick240 is online now   Reply With Quote
Old August 10th, 2019, 11:29   #34
[486]
TDI(s): 02 golf ALH
well kubota has the injection pump in the block, so it runs hotter than an external injection pump
Black Diesel skicat Fuels & Lubricants 17 September 26th, 2012 05:36
Diesel and Black Carbon Blonde Guy TDI (Diesel) Emissions 9 January 6th, 2011 20:52
New 2010 black diesel DGolder2 TDI 101 3 December 24th, 2010 21:16
has anyone tried black diesel ? bigwheels0 Fuels & Lubricants 7 August 22nd, 2007 16:28
Finally Here! black-Black-BLACK 2004 TDI Variant GETTIN_a_TDI Passat TDI Picture Gallery 14 October 13th, 2004 10:33
Page generated in 0.14191 seconds with 13 queries
[Output: 68.42 Kb. compressed to 61.66 Kb. by saving 6.76 Kb. (9.88%)]
