firehawk618
I am getting this code constantly.
02390 - Control / Regulation for Ambience Lighting (E400) 009 - Open or Short to Ground
00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective
I am very good with electronics and retrofitting. This car started as a very basic model. I have since then retrofitted the following electronics: RNS510, Windshield with rain sensor, auto dim rear view mirror, puddle light exterior mirrors, full fis cluster, highline CCM, highline CEM, MFSW, euro siren and probably a few other things I do not remember currently.
These codes started after retrofitting the mirror / rain / light sensor.
I have disconnected the interior light sense wire that goes from the auto dim mirror to the dome light. It tells the mirror when the interior ligths are on and prevents the mirror from dimming while they are on. I thought this had to be the cause. Nope no change so I reconnected it.
As far as the wiper switch error goes I have swapped out the switch for 2 known good ones. Again this started after the rain sensor retrofit.
Here is my questions:
1. Ambient lighting error, Eeactly what circuits does this code relate to? I am having a hard time finding any documentation and the ross-tech site that covers this code is not helpful.
2. Any ideas on the intermittent wiper switch error? The code is constant. It comes back as soon as I clear it. All appears to function properly as tested on the road and as well as monitoring blocks in vagcom.
I have visually inspected both vanity mirror lights, ambient lighting on overhead console, footwell lighting and all appear to illuminate normally.
If anyone knows exactly what circuits this code is talking about *ambient lighting* that would point me in the right direction.
Thank you!
***The instrument cluster code is my own fault, long story but I caused it. The cluster works fine.***
Here's my full scan:
Sunday,16,July,2017,19:00:46:58197
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: 3VWRT71K16M626490 License Plate:
Mileage: 370270km-230075mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K16M626490 Mileage: 370270km-230075miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2294168
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63CFD04DA2B6ED5994-8036
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 40853FC113609641A9-8014
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 70E5AF01634046C119-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000015414
Coding: C4011E004104181414140014141414140001730F5C
Shop #: WSC 12345 123 12345
VCID: 2F676C7DBEFE193940-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00063477
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130114 054 0403
Coding: 00405677
Shop #: WSC 12345
1 Fault Found:
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD02HUKQ
Coding: 0012627
VCID: 2E597179B9F410314B-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0A0C084DI
Subsystem 3 - Serial number: 6342MSME0A071124/
Subsystem 4 - Serial number: 6351HSME070B460A5
Subsystem 5 - Serial number: 6361HSME0730227D2
Subsystem 6 - Serial number: 63727SME0672544E2
Subsystem 7 - Serial number: 63827SME0529452E2
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AC HW: 1K0 953 549 AC
Component: J0527 010 0045
Coding: 0003041
VCID: 73EFA00D12567DD9E4-8026
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
1 Fault Found:
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 972 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0021107
Shop #: WSC 03313 444 58943
VCID: 356B5E155CA223E90A-8060
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 01081001211403
Coding: E9807F1640020200001002
Shop #: WSC 00066 123 12345
VCID: 6DDBB6757472AB2932-8038
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C8 035 684 E
Component: RNS-MID H61 4366
Revision: AB001001 Serial number: VWZ6Z7M8071043
Coding: 04000400040000260006
Shop #: WSC 09003 957 00200
VCID: 2A517D69451C7C1197-807E
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V11 8407
2 Faults Found:
02633 - Antenna for Satellite Tuner
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
01550 - Signal for Reverse Gear
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001143
VCID: 3669591941A428F103-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.4 D04 1606
VCID: 32616509ADCC34D12F-8066
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 12900E8801064E3600020F8FF0080F0E50A500
VCID: 0201F5C95DEC4451FF-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001142
VCID: 3777541D46AED1F918-8062
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000080
VCID: 31636A05A8CA0FC956-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000080
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B7675B4F26B2972-8078
End-------------------------(Elapsed Time: 01:48)--------------------------
Thank you!
www.Ross-Tech.com
Coding: 0050071
Revision: 00T12001
Coding: 0021122
Coding: 00063477
Shop #: WSC 12345
Coding: 00405677
Shop #: WSC 12345
1 Fault Found:
Coding: 0012627
Coding: 0003041
1 Fault Found:
014 - Defective
Coding: 0021107
1 Fault Found:
014 - Defective
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Coding: 0001143
Coding: 0001142
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 153
Mileage: 370272 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:32
Coding: 0000080
Coding: 0000080
