HPsenicka
- Joined
- Aug 15, 2013
- Location
- Orangeville, Ontario
- TDI
- 2 x 2004 Jetta Sport BEW (Malone Stage 1.5), 2014 GSW TDI - Wolfsburg Edition, 2015 Passat TDI -Sport Trim
I'm stuck...
Following the Bentley instructions for dismantling the aft portion of the center console (MK5 Jetta TDI with DSG) to access the parking brake cable adjuster.
I have managed to locate all of the screws, and the assembly is somewhat loose, but the next step apparently requires unclipping the rear cover/cupholder portion that faces the rear seat passengers.
For the life of me I cant seem to figure out to detach that from the main assembly.
Do I need to pry them apart with a flat bladed screwdriver or similar tool, or is there a magic wand of some kind that I am missing?
.. perhaps I just haven't applied enough alcohol??
