CBM
Possible CCM issue
Going down the list of items left to repair on my car. There is not much left thankfully. When I scan the car I get errors for all the door locks EXCEPT the drivers. The trunk release just stopped working recently and that is the motivation behind getting this sorted. Scan showed intermittent signal to CCM. I have seen post where people remove the CCM and clean the connections, reassemble and they are good. I don't know how realistic that is in my case...
Windows, interior lights, everything else works as it should. My key FOB never worked so maybe that is related, maybe its a dead battery. Looking for some suggestions on how to proceed. As a side note the ESP light was popping on and then went away after my manual swap. The trunk switch did have a short period of working less and less frequently until finally 100% fail.
