GoremanX
Shaftec is on the bottom.
It had about 200 miles on it when the tone ring fell off. The tone ring is not broken or damaged in any way, it just came off. It was causing the ABS to activate on the right front of the car, especially at high speed, thereby sending me careening into oncoming traffic every time I pressed the brake pedal. I ended up disabling ABS altogether to stop this terrifying behavior.
Also, the outer CV on the Shaftec is almost completely devoid of grease. It was vibrating horribly on the highway in 5th and 6th gears. This after about 2500 miles.
Cheap Chinese garbage... I don't have the appropriate swear words to describe how aggravating this is.
