Old July 18th, 2017, 21:11   #766
Lightflyer1
Lightflyer1's Avatar
I was just reading over the EA288 Self Study Guide and it seems this filter would only provide filtered fuel to the HPFP. The output from the HPFP goes directly to the rail. Then to injectors and and a return off the rail to the filter. The injectors have a separate return to the tank. If the HPFP grenades it will get to the rail, injectors and tank. Starting page 34.
http://pics3.tdiclub.com/data/517/820433_EA288.pdf
2015 Beetle TDI with upgraded rns315 with backup cam/nav and projector headlights.
Old July 20th, 2017, 16:55   #767
jason_
Thanks for confirmation. Still a cp-****... Seems a cp3 is a better spend of money for a fuel system upgrade.
Sent from my One using Tapatalk
jason_ is offline   Reply With Quote
Old July 20th, 2017, 19:07   #768
Lightflyer1
I was wrong. Andrew emailed me today. I hope he doesn't mind.
"Hello David, in response to your post:
The returning fuel from the pump and injectors will go to the new return filter, just before the pulsation damper.
The return fuel from the rail will continue to go into the factory filter.
With the new Pure Flow device, fuel going into and out of the rail will always be clean.
Don't worry!!
Andrew "
Old July 21st, 2017, 03:17   #769
jason_
I guess I'm confused, Im assuming the 15s need a married pair to be completely effective, the filter kit plus a pure flow, and according to Andrew, the 15s also use a pure flow?
Old July 22nd, 2017, 19:41   #770
1986.5supra_kid
TDI(s): 2010 jetta
Fuel Economy: 33-41
photobucket links dont work. id like to protect the cp4. is this the answer?
1986.5supra_kid is offline   Reply With Quote
Old July 22nd, 2017, 19:59   #771
mr_y82
Yes. I think you may have to find a used one for the time being... someone will correct me if wrong. CP3 conversion, another 2micron fabrication, is also an option. Cheers!
Malone Stage 2 Econo-Tune!;BuzzKen downpipe w/ cat!
2MicronTech Contain Flow and Pure flow Adapter FROSTHEATER
Appalachian Diesel Works, NC!(TRUSTED TDI MECHANICS)
Pre-tune: ~10k-70k mi = 40.5 mpgs; mpgs since tune_f_u_e_l_l_y_ ^
mr_y82 is offline   Reply With Quote
Old July 22nd, 2017, 21:40   #772
turbobrick240
I bet you can get a new one if you contact Andrew. They look a bit different than the mk6 filter- I think they may mount differently as well.
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 17:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 16:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 05:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 22:08
Page generated in 0.15098 seconds with 12 queries
[Output: 81.98 Kb. compressed to 71.58 Kb. by saving 10.40 Kb. (12.69%)]
